Old Jul 23, 2020, 12:36 PM
How-Tos on this Topic
Last edit by: DaveGS4
Browse all: Exterior Guides
Print Wikipost
2009 IS350 - Left side-view mirror "loose" fixes (merged threads)
Old May 10, 2012 | 11:24 AM
rwood001's Avatar
rwood001
Default 2009 IS350 - Left side-view mirror "loose" fixes (merged threads)
The side mirror on my '09 IS 250 has become loose and acts like a bobble head! Is there anyway to resolve the problem without spending a few hundred $$$? Can it simply be tightened?
Thanks,
Robert
Old May 23, 2012 | 05:18 PM
ljwjr1's Avatar
ljwjr1
Default 2009 IS250 Driver Side Mirror
Did you find out how to fix the side mirror?
Old May 24, 2012 | 08:56 AM
shouran's Avatar
shouran
I have noticed that both of my side mirrors get moved at the car wash and didn't used to. Have been unable to find any instruction on how or if they can be tightened. It may be a huge deal involving removing the whole door panel as doesn't appear can be done from the outside.
Anyone have an answer to this??
Old May 24, 2012 | 08:58 AM
shouran's Avatar
shouran
Default Side Mirrors Loose - 2006 IS 350
Anyone have an answer/feedbacl on this??
Old May 24, 2012 | 11:18 AM
kinglexus99's Avatar
kinglexus99
I think you may have to remove the mirror from each housing to access the bolt that holds it to the arm that's attached to the car. Maybe you could just tighten the bolt? Try searching for puddle lamp replacement threads. There is one that shows how to remove the mirror from the housing.
Old May 24, 2012 | 01:36 PM
Gville350's Avatar
Gville350
#1 - Shame on you for using a motorized car wash
#2 - Mirrors normally get tossed about within those things
#3 - Don't bother tightening, not worth your time
Old May 28, 2012 | 07:45 AM
shouran's Avatar
shouran
Thanks for the opinions and stating the obvious. Nothing wrong with using most modern car washes.
If you don't have a solution to the question don't comment. Thanks.
Old May 28, 2012 | 07:46 AM
shouran's Avatar
shouran
Default Thanks
Thanks nixx621. I have seen those threads before and will check out.
Old May 28, 2012 | 06:56 PM
aspeckt's Avatar
aspeckt
when i drive speeds of 60+ mph my left side view mirror vibrates so fast that it makes anything i look at in it very blurry. is this the same thing you're talking about? I might need to tighten it too
Old May 29, 2012 | 05:14 PM
anthrax144's Avatar
anthrax144
I have this same issue with my passenger side mirror. I replaced the puddle lights a while back and tried tightening it up but was unable to locate the correct nut to remedy the issue. If any one else has done this, I'd like to hear as well.
Old Jun 18, 2012 | 08:10 PM
mykeeh33's Avatar
mykeeh33
Default side mirror broken
so i was just driving and my passenger side mirror is loose every time i brake or acc
it moves back and forth any one know what can be the issue and what i can do to fix it?
Old Jun 18, 2012 | 08:27 PM
Sango's Avatar
Sango
What year is the car? Under warranty?
Old Jun 18, 2012 | 08:31 PM
mykeeh33's Avatar
mykeeh33
its a 2009 and yeah i still have warranty.
Old Jun 18, 2012 | 10:12 PM
KillaIS250's Avatar
KillaIS250
Take it back, let them fix it
As long as you didn't physically break it, they should take care of it for you.
ISCjonny's Avatar
ISCjonny
did you swap out your puddle lights recently? possible the mirror isnt clipped back in. 2 hooks on top and 2 clips on bottom. push firmly around the middle of the mirror to see if it'll clip back in.
