Oil Qty question?
Old Feb 22, 2012 | 10:10 PM
enlight's Avatar
enlight
Default Oil Qty question?
I know that the IS stated capacity is 6.7 qts total.
When doing a long change interval, without changing the oil filter how much would you say remains in the filter and housing area?
Old Feb 23, 2012 | 01:06 AM
KillaIS250's Avatar
KillaIS250
This should help you
Originally Posted by javyLSU
From the factory service manual, page PP-27:
Code:
Drain and refill w/ Oil filter change    6.3 liters (6.7 US qts, 5.5 imp. qts)
Drain and refill w/o Oil filter change  5.9 liters (6.2 US qts, 5.2 imp. qts)
Dry fill                               7.2 liters (7.6 US qts, 6.3 imp. qts)
Javier
https://www.clublexus.com/forums/is-...-question.html
Old Feb 23, 2012 | 05:47 AM
Kurtz's Avatar
Kurtz
Why are you not changing the filter?
Using the standard filter anyway it should be changed more often than the oil itself when doing especially long OCIs. (ie you could run Amsoil for 20k miles no problem but should be changing the filter by 10k if doing so)
Only case I could think of you'd do the opposite is if you're running the synthetic media TRD filter, but then running conventional oil with 7500 or 10k changes....but I've not seen anyone do any definitive testing on how long the TRD filter is good for, and would think you'd still be better off running synthetic and changing both on a long OCI.
Old Feb 23, 2012 | 07:27 AM
Sconnie's Avatar
Sconnie
She is a thirsty girl...
NikonGuy
Dec 20, 2014 03:15 PM
USCRugby
Apr 21, 2013 10:52 AM
JerzeeB
May 26, 2011 02:03 PM
atnexus
Jan 25, 2010 09:31 AM
wakaru8
Dec 23, 2009 08:07 AM
