world first is250 trasformation to is-f new updated
#136
I don't want to remove it right now, but since I'm at 165,000 miles the engine will be replaced in the future (250,000k) range and I might go with this option instead of the 350 engine but it depends is the engine you have faster than the stock 350 engine...in regards to 0-60 4.6 seconds or whatever it is?
#137
It will be on par and with an extra 50 ft/lbs of torque, it should be quite fun. Plus, you'll have the aftermarket support to have the engine built and boosted.
#138
so I've seriously been considering doing this same swap strictly for the option to boost the hell out of the 3uz down the road. THe downside is that, with the 3uz and A761E 6 speed, it will be slightly slower than a stock 350 and quite a bit slower than my car is now. This is according to some simulation software that appears pretty darn accurate. I attribute this to the extra 50lbs of weight I added for the v8, and the slightly longer gearing in the A761E.
If its as plug and play as paulo says, this should be a pretty good way to put some real power down with some boost . THe compression ratio is a more boost friendly 10.5:1 instead of the current 12.1:1. What do you guys think? worth the effort initially? I'd be aiming for 400whp and 425torque after a boost which should be good for low 12's pushing 117mph in the 1/4.
I've found an engine/ecu for 2400 and the trans for 700. Seems relatively cheap until you add the costs of turbo and peripherals. We'd probably be talking about 6-7k total investment.
Yay or nay?
Yay or nay?
#139
Personally, the resale value of my is350 + $6k would still NOT get me into an ISF...I would seriously consider the above option if I had the commitment and execution time available.
Paulo - whats good with that motor of yours!? Any turbos starting to spool ?
#140
I'm in the same boat with the resale value of my car. I've been researching some salvaged LS430,GS430 and SC430's and found quite a few for 500 or less. I figure I could buy the whole car salvaged, pull the motor and trans and sell off or scrap whatever I can along with my is350 motor. I might even try to put a kit together to make it easy for future swappers.
I'm just not sure if a 4.3 + turbos will fit in the engine bay.
Paulo we wanna hear from you again!!! Let us know how its going.
#141
I know Paulo already said it was a direct swap, but I had to confirm I wouldnt be surprised by something. Its all the same part numbers down to the bolt for engine mounts.
http://is.sewellparts.com/oem-catalo...S350-2006.html
http://lexus.sewellparts.com/oem-cat...C430-2006.html
#142
#144
#145
Yay or nay?
Yay or nay?
#146
I downloaded the wiring diagrams for the SC,LS, and GS just to be sure I've got everything I need, but I havent started going through them. They look similar obviously, but the devil is always in the details.
#147
If youre committed to boosting the 3uz then it would def. be the way to go! Ive seen the tranny at the price you mentioned but couldnt find the engine/ecu under $3k. If you can effectively source the hardware for a good price I'd say go for it!
#148
guys i promise you it sound like nascar v8 and it only one of kind in this country . yes just need to get boost .
well there is space in the front of engine where i can mount the turbo just remember i got is-f kit so my engine bay got extra space as is bit longer then std 250
#150
http://www.toydiy.com/parts/p_U_2007...TQKA_1107.html
12361‑50220 insulator 12311‑50150 bracket
and you need idler and bracket to replace the power steering on 3uz
http://www.toydiy.com/parts/p_U_2007....html?hl=16603
16607‑50010 bracket
