Valve stem cap?
Old Apr 20, 2011 | 12:05 PM
clubfoot's Avatar
clubfoot
If you drive in the salted snow belt DON'T use metallic valve caps,...including OEM!! They will corrode to the valve stem, and snap off the TPMS stem if you try to remove them,...this is from experience. Very expensive! Use silver colored plastic caps
Old Apr 20, 2011 | 12:11 PM
Mv350's Avatar
Mv350
was just about to post about that^^^^^^^
Old Apr 20, 2011 | 12:37 PM
B16da9's Avatar
B16da9
If you guys replace your caps make sure they are either plastic or aluminum. If you use a cap made out of steel it will fuse to the aluminum TPMS valve stem.
Old Jan 4, 2012 | 09:25 PM
kl323's Avatar
kl323
Hey all,
Reviving this thread because I'm in the market for caps.
I found two on Amazon:
http://www.amazon.com/Mr-Gasket-3663...=pd_sim_auto_3
http://www.amazon.com/Anodized-Alumi...5722775&sr=1-9
One is chrome plated and the other is anodized aluminum.
Both have great reviews...
Any thoughts? I know it's cheap but I don't want to end up ruining my TPMS either...
Thanks!
Old Jan 5, 2012 | 05:26 AM
Joeb427's Avatar
Joeb427
True.
You have to use anti-seize lube on the threads.
I use anti-seize lube with the stock air caps,
I like the stock air cap style.I bought a set for the wife's CR-V.
Old Jan 5, 2012 | 07:26 AM
flowrider's Avatar
flowrider
Veteran: Air Force
It's a dissimilar metals issue, read the thread below for more information:
https://www.clublexus.com/forums/is-...alve-caps.html
Lou
Old Jan 5, 2012 | 11:55 AM
kl323's Avatar
kl323
Originally Posted by Joeb427
True.
Is there a particular type of lube to use? I've seen that there are copper based ones and nickel based ones.
Old Jan 6, 2012 | 10:43 AM
Joeb427's Avatar
Joeb427
There's a bunch of different companies that make anti seize.
I use this and bought a tube of this stuff somewhere awhile ago.
It's brown so it may be zinc or could be nickle.
Stuff is made in Germany.
Old Jan 6, 2012 | 11:03 AM
clubfoot's Avatar
clubfoot
After losing my front driver's side TPMS valve stem to a corroded Lexus OEM valve cap I run El-cheapo plastic silver colored valve caps for the local auto parts store,...they're great in winter and I won't get anti-seize residue on my gloves or hands servicing tire pressures.
Old Jan 6, 2012 | 11:14 AM
Joeb427's Avatar
Joeb427
How do you get anti seize on your gloves and/or hands?
I never do.It's only on the thread under the cap.
Old Jan 6, 2012 | 08:27 PM
clubfoot's Avatar
clubfoot
Try putting them on with gloved hands at -30C,...if you use plastic caps no anti seize is necessary.
Old Jan 6, 2012 | 11:12 PM
UniSlayEX's Avatar
UniSlayEX
valve stem caps dont have anything to do with TPMS. Youre good to go. Were the L caps the lexus branded ones?
Old Jan 7, 2012 | 04:41 AM
Joeb427's Avatar
Joeb427
Thats -22 Fahrenheit for me.
I've never been in that temp.Must be brutal.
Old Jan 7, 2012 | 06:32 PM
clubfoot's Avatar
clubfoot
This is what happens to an OEM Lexus Chrome TMPS valve stem in a salt infested Canadian winter,...and about $200.00 later after installation and programing,....
Old Jan 7, 2012 | 08:12 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Did you not read my link above Did you not read my statement on dissimilar metals I don't make this stuff up And, look at what happened to clubfoot
Lou
GS450hSE
Nov 8, 2018 04:02 AM
nevernu
Mar 27, 2012 06:11 PM
whise
Wheels, Tires & Brakes Forum
Jun 17, 2011 09:00 AM
SoyMilk
Jun 5, 2008 11:17 PM
dnszoom
Jul 23, 2006 04:02 PM
