Wheel offset question
Old Jan 4, 2011 | 09:54 PM
LexusGuy35's Avatar
LexusGuy35
Default Wheel offset question
Does a higher # offset bring the wheel out more for a more flush look or in more? For a example would a +40 offset be out more then say a +30 offset and by how much? Also anymore know the offset of stock 18" staggered wheels?
Old Jan 4, 2011 | 10:05 PM
projectdna's Avatar
projectdna
offset = how far the plane of the wheel's centerline is from the plane of the wheel's inside mounting face.
for example...
+30 = centerline is 30mm farther inside the mounting face
+40 = centerline is 40mm farther inside the mounting face
so assuming the same wheel diameter and width, a wheel with +30 offset would be 10mm farther out than that of a +40 offset.
(ergo, the greater the (positive) offset, the more sunken in the wheel barrel is.)
i don't know the offsets of the oem 2is 18's off the top of my head, but a search would help you find that answer.
Old Jan 4, 2011 | 10:08 PM
projectdna's Avatar
projectdna
see this for a more technical explanation:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jan 5, 2011 | 04:44 AM
Lexs350's Avatar
Lexs350
I recall the offset for OEM stock 18's is +40
Old Jan 5, 2011 | 11:33 AM
LexusGuy35's Avatar
LexusGuy35
for example...
Thanx this helps a lot.
Parsa
Jan 2, 2023 05:55 AM
montz450
VIP Style
Feb 16, 2011 11:46 AM
SWSC400
Wheels, Tires & Brakes Forum
Jan 6, 2006 12:07 AM
Team Lexus
Dec 6, 2005 03:33 PM
RNM GS3
Jul 14, 2002 06:43 PM
