Headlight problem
Old Dec 29, 2010 | 10:46 AM
Reed7139's Avatar
Reed7139
Default Headlight problem
For the past couple of weeks my passenger side headlight has been going off and on while driving. It is significantly dimmer than the driver side light. However both headlights have now gotten very dim and last week all the lights on my dash (radio, clock....) went out then my car wouldn't crank. So I took it to the dealership today and they are telling me that the computer that controls the headlights is going bad and needs to be replaced and will be over $3000.00.......Does that sound right to anyone else bc to me it sounds like a RIP OFF!
Old Dec 29, 2010 | 10:56 AM
jbounnoi's Avatar
jbounnoi
They can range from approx. $600(NON HID 06-10) - $1400(HID 06-10) - $3000(LED-HID '11)
http://is.sewellparts.com/
Look here for your specific year, and if you login you get a discount for being apart of CL.
Old Dec 29, 2010 | 11:09 AM
Reed7139's Avatar
Reed7139
Thanks! =)
Old Dec 29, 2010 | 11:39 AM
slee18's Avatar
slee18
sound like your battery is dead. have the battery checked if it is a 06-07. Doesnt sound like the headlights are the issue. Maybe the altenator is bad too.
Old Dec 29, 2010 | 11:45 AM
Reed7139's Avatar
Reed7139
Both have been checked are and ok.
Old Dec 29, 2010 | 09:24 PM
youngnique's Avatar
youngnique
I've been having the same issue... Help anyone?
Old Dec 29, 2010 | 10:08 PM
TicDatDo's Avatar
TicDatDo
I had the same issue a few months ago. Brought my car into the dealership and they said the bulb was just getting bad; "not enough power to generate light so it powers down and then back on". They just changed the bulb and it worked fine ever since! it should be under warranty too. Those phillips bulbs are expensive!
rome99LS
25
Aug 9, 2017 11:05 AM
Mortis101
IS F (2008-2014)
Nov 30, 2015 06:54 AM
lakersfan0
Apr 25, 2009 06:51 PM
Phillycat-24
Mar 6, 2004 07:35 AM
scpower300
Lighting
Feb 25, 2003 08:08 PM
