Key Unlocks/locks Door But Won't Start Car! Help!
Old 12-19-10, 03:44 PM
andyroo
andyroo's Avatar
Originally Posted by MiiK350
If the freeways weren't as bad as they are right now in this weather, I'd stop by and hep you figure it out.
Try and push the brake pedal down as hard as you can.
tried pushing down the break pedal really hard and jerking the steering wheel while pressing the start/stop button, no go.
Old 12-19-10, 03:48 PM
MiiK350
MiiK350's Avatar
Is the car in drive or reverse?
Old 12-19-10, 03:51 PM
andyroo
andyroo's Avatar
nope, shifted in park just sitting in my garage.
Old 12-19-10, 04:16 PM
DryEye
DryEye's Avatar
Do you have the vehicle manual? If you do, you can look at page 494 and It's the section "If the electronic key does not operate properly." I don't know if the page is the same for your manual. Hope this helps.
Old 12-19-10, 04:23 PM
Big Mack
Big Mack's Avatar
Exclamation
The only variable is the battery, so don't be so quick to dismiss that as the cause. Isn't it a thin watch battery that could go in backward? I would open it up and see if flipping it does anything. The buttons on the keyfob may still work with it backward, but the signal emitter may not.
Have you tried searching for how to change out the battery? Perhaps your owner's manual can provide more info on it if there is a special process involved.
Big Mack
Old 12-19-10, 04:25 PM
andyroo
andyroo's Avatar
Thanks for the heads up, but already went through the manual and tried all the options it gave
Old 12-19-10, 04:54 PM
andyroo
andyroo's Avatar
Tried switching out the batteries between my spare key and master key. Made sure it was put in the key right side up. still no go
Old 12-19-10, 05:00 PM
llamaboiz
llamaboiz's Avatar
my bad, didn't see your keyfob battery comment... but on that note, you sure you have the positive and negative correct?
Old 12-19-10, 05:06 PM
andyroo
andyroo's Avatar
yeah, checked and double-checked to see that the batteries were put in right side up, but to no avail ;(
Old 12-19-10, 05:22 PM
Micaiah
Micaiah's Avatar
Soooooo........no relation to what I said about the alarm going off at any time in the recent past?
aarongue6
aarongue6's Avatar
Just a random thought, have you tried to unplug your car battery to reset the ECU, or have you checked to make sure the car battery is still good?
Old 12-19-10, 05:26 PM
andyroo
andyroo's Avatar
hmm.. i don't seem to recall the alarm going off any time recently
Old 12-19-10, 05:31 PM
andyroo
andyroo's Avatar
yup, tried unplugging the positive terminal for the car battery to reset the ECU, and the car battery is fine too.
andyroo
andyroo's Avatar
oh and another thing, when I enter the car and look at the dashboard it usually says "key not detected" but it doesn't do that. the dashboard is completely blank and doesn't light up at all regardless if i am holding the key or not.
Old 12-19-10, 05:55 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Does the green light (on the start/stop button) come on when you press the brake pedal? Have you tried putting the key fob right up against the start stop switch when trying to start the car? You can also try cycling the metal key in the door cylinder, with the door closed, to make sure the security system isnt activated.
Quick Reply: Key Unlocks/locks Door But Won't Start Car! Help!
