Spacers??
Hello everyone. I've got some questions about spacers..I know nothing about them. I've got an 09 is250. I want it to be flush. How much are spacers, what brands are there, what size do I get for it to be flush (I've got 17s stock) do I need them for the front? Cuz I jst want it to look more aggressive from the rear. Thanks in advance.
You can do 15mm front and 20mm rear to get it flush. You might be able to get away with even 20mm front and 25 mm rear too if you want it to be really flush, but I ran 15mm front and 20mm rear for roughly 8k miles and spacers/wheels were fine.
Ichiban or Project Kics
https://www.clublexus.com/forums/is2...ar-spacer.html
I have a set of custom spacers. Look at the link above. It will be pretty flush pics in there too. Don't get the ichiban. I had them and felt slightly vibration. I don't know about the project kick. If you interested in my set lmk. |
I should make a thread on how to measure for spacers since everyone is always asking. First off H&R are pretty much the best on the market, made in Germany. They are the most popular used on VW's, Audi, and BMW's. Im pretty sure I saw they make them for lexus on there website. You dont want to risk on a cheapo brand that will crack on you.
Now on now to measure. Make sure your car is on level ground. Take a piece of string and tie a bolt around one end. Now tape the top part of the string to the center of your fender allowing the nut to hang down. Take a ruler and measure from your tire to string. That is how many mm spacer you will need to be flush with the fender. Add more if you want some poke. Do the same for the rear as they sit in differently from the front |
Originally Posted by JDKane527
(Post 5669641)
hmmm i might sell my 15 or 20 mm ichiba spacers?
Originally Posted by flektone
(Post 5669718)
Originally Posted by lex09
(Post 5669737)
Very informative, thank you. How much will a set of hr spacers cost? Does the size matter on cost?
(Post 5669744)
yea size will matter. think on my VW my 8mm were $50 for the set and my 15mm were around $75 for the set. Got to H&R's website
(Post 5670010)
Ok cool. One last question..what about installation? Is it easy so I can do it myself or do I have to have a shop do it?
25mm front and rear. ichiba is a good company that has built in studs in the spacers so they're super easy to install
