extended studs question guys!!!
i changed the extended studs, if i want to take out the spacers do i have to change back to the oem studs, or i can keep them on the car for good?
thanks guys pls help!
It depends on how long the studs are and what kind of lug nuts you are using. If you use a significantly longer stud, the OEM lug nuts won't be able to handle the increased length and you'd have to use an open-ended lug nut to keep from swapping the studs out again.
Javier
Javier
Bullskim
Nov 21, 2008 12:33 PM
