Will those wheels fit? START HERE.
Old Jun 9, 2010 | 05:57 PM
  #1201
saiyajin's Avatar
saiyajin
hey guys what would be a good tire size if i plan to run 18x8.5 all around as I have an AWD, dont plan to go stagger route with a +35 offset and a mild drop maybe 1finger gap without any fender mods???
also would going 18x9 all around be possible or would it be too wide for the front??
thanks a bunch!!
Old Jun 9, 2010 | 06:37 PM
  #1202
Osudoc2012's Avatar
Osudoc2012
I've got an 07 IS250 Xpack. Right now running the x stock rims. I'm wanting to fill out the fender wells, but not go huge. Either 18's, or maybe 19's, but no larger. DD with really crappy roads. Should I go with a wider rim? or just change up the offset? Thanks guys!
Old Jun 9, 2010 | 07:42 PM
  #1203
acefalcon2's Avatar
acefalcon2
thanks a bunch!!
any of your options are fine... get the right offset and tires
i DD with 19" and a wider rim... and lower offsets
Andre
Old Jun 9, 2010 | 10:23 PM
  #1204
saiyajin's Avatar
saiyajin
thanks a bunch!!
Andre
thanks acefalcon but thats what i am asking... i was wondering which tire sizes would suffice and if a +35 offset all around is good for a 18x8.5 and if a different offset is needed if i go 18x9
Old Jun 9, 2010 | 11:27 PM
  #1205
Mv350's Avatar
Mv350
8.5+35 all around or 9 +35 all around would work well with 225/40-255/40, depends how low you wanna go. or no drop at all.
Old Jun 10, 2010 | 02:28 PM
  #1206
Mikey912's Avatar
Mikey912
ok guys i found some rims i like and need to know if this would work on a 06 IS350
F: 20x8.5+38 - 2.75" lip
R: 20x10.5+45 - 3.5" lip
if so what size tires would you recommend?
Old Jun 10, 2010 | 03:51 PM
  #1207
acefalcon2's Avatar
acefalcon2
225/35 Fronts
275/30 Rears...
sounds like the Work SC1 for sale by 97Soarer
Andre...
Old Jun 10, 2010 | 04:09 PM
  #1208
Mikey912's Avatar
Mikey912
lol could be
Old Jun 10, 2010 | 11:16 PM
  #1209
ilv1004s's Avatar
ilv1004s
18x9 +37 on Potenza G3's (255/35/18) around 70% tread left
18x8 +29 on Potenza G3's (235/40/18) around 70% tread left
dont worry about the tyres
will the wheels be flush?
and will they clear the IS350 brakes?
Old Jun 11, 2010 | 12:45 AM
  #1210
Mv350's Avatar
Mv350
they wont be flush. depends on what your dropped on and i can tell you what size you'll need.
Originally Posted by Mikey912
lol could be
wont clear your front brakes. need 10mm spacer.
Old Jun 11, 2010 | 07:47 AM
  #1211
acefalcon2's Avatar
acefalcon2
you'll actually only need 5mm... i have a 10mm spacer and have a good 8mm space between the calipers and the closest part of the spokes
Andre
Old Jun 11, 2010 | 05:18 PM
  #1212
ilv1004s's Avatar
ilv1004s
how much are we talking about ?
im planing to drop on bc's
Old Jun 11, 2010 | 05:35 PM
  #1213
Mv350's Avatar
Mv350
depends on how low. how much of a drop. 1 finger gap. 1/2 finger. full slam. im 19x8.5+15 and 19x9.5+15 and still am barely flush.
Old Jun 11, 2010 | 08:17 PM
  #1214
integlspwr's Avatar
integlspwr
19x9.5 +22 all around what size tires? ill run mad stretch with no problems.
Old Jun 11, 2010 | 10:01 PM
  #1215
acefalcon2's Avatar
acefalcon2
225/35 all around or 235/35 is good
i think
Andre
