Will those wheels fit? START HERE.
Old Apr 30, 2010 | 10:05 AM
  #1081
mikez's Avatar
mikez
Upgrade to dry sump
Old Apr 30, 2010 | 10:23 AM
  #1082
HawkIS's Avatar
HawkIS
Default Wheel advice
I poseted this question before but got mixed responses. I am purchasing some wheels that are 19x9 annd I am deciding between a +37 and +20 offset. I will be running 235/35's. I would like to get the +20 but I don't want the wheel sticking out too far and I don't want to get smaller tires and stretch them. Am I safe getting the +20?
Old Apr 30, 2010 | 10:37 AM
  #1083
ChrISF's Avatar
ChrISF
customize your oil pan. all it takes is a grinder, a welder, and some common knowledge.
Old Apr 30, 2010 | 12:21 PM
  #1084
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
nah, cheaper to buy oilpans than doing that.
Old Apr 30, 2010 | 04:03 PM
  #1085
HawkIS's Avatar
HawkIS
Anyone? Please...
Old Apr 30, 2010 | 04:13 PM
  #1086
datplayaz's Avatar
datplayaz
Are you planning to run 19x9 on all four?
  #1087
Sytfu_IS's Avatar
Sytfu_IS
Is there a reason why you're not running a staggered setup? 19x9 37 will fit np for the front on 225/35 sitting almost flush.
Old Apr 30, 2010 | 04:46 PM
  #1088
HawkIS's Avatar
HawkIS
Yes, I plan to run 19x9's all around and the offset for the front will be +37, it's the rears I'm not sure of.
I'm not running staggered because it turns out to be a lot more expensive if I get the wider wheel and bigger tires.
Old Apr 30, 2010 | 05:28 PM
  #1089
datplayaz's Avatar
datplayaz
If you're really set on running 19x9 all around with 235/35 you'll need a high offset up front (like in the 40's) and a low offset in the rear. But I think it will a lot better if you go with a staggered setup, btw I just saw that you're in UT too, where are you at?
Old Apr 30, 2010 | 05:56 PM
  #1090
cro126's Avatar
cro126
Default Wheels Help
Hey guys i have a stock AWD IS250. I found some nice wheels for a good price and was wondering if theyd fit my stock setup. And what spacers/ lowering springs should i install with them?
The sizes are:
19x8.5 +40 w/ ~2" lip
19x9.5 +45 w/ ~3" lip
with tire sizes of:
front-215/35/19 Falken FK452
rear-225/35/19 Federal SS595
Old Apr 30, 2010 | 06:11 PM
  #1091
HawkIS's Avatar
HawkIS
What's the downside of not going staggered?
I'm in provo. You?
Old Apr 30, 2010 | 09:02 PM
  #1092
Mv350's Avatar
Mv350
no real downside of not being staggered, but low offsets are gunna be harder to find.
cro126-those will be good, but get springs or coils, then you should know how big of spacers youll need
Old Apr 30, 2010 | 09:14 PM
  #1093
Damaster32's Avatar
Damaster32
ill give this a try but i dont think it will fit
What you guys think
SSR SP1
Front 19" 9.0 31mm offset
Rear 19" 10 37mm offset
Old May 1, 2010 | 09:47 AM
  #1094
mercedessx's Avatar
mercedessx
Front wheels : 19x8.5 ET35
Rear wheels : 19x9.5 ET35
What spacers will i need to get a flush fitment
Old May 1, 2010 | 09:48 AM
  #1095
venZon's Avatar
venZon
10-15mm spacers to get them flush
