Will those wheels fit? START HERE.
#5596
Before you lower it though, I would look into rolling all fenders at the bare minimum.
#5597
Do you guys think the setup below will be OK? I want to be flush don't want to be poking or rubbing.
I have an 08 IS250 RWD lowered on Eibach Pro Kit (1.4 front - 1.0 rear)
WEDSSPORT TC105N RIMS
FRONT 18X8.5 +32 WITH TOYO PROXES T1 SPORT 235/40ZR18
REAR 18X9.5 +35 WITH TOYO PROXES T1 SPORT 265/35ZR18
#5599
Ive seen 265/35/18 on 8.0" wheels before and it doesn't look in particular like anythings wrong. However that doesnt mean its safe. I have yet to see a 265 that a manufacturer recommends to go on less than a 9 inch rim. But like I said Ive seen it done. I personally wouldn't suggest it though since the sidewalls won't have the proper elasticity they require for optimal performance.
#5600
#5601
19" Infiniti g35 Rays Wheels on AWD is250
I don't know if I'll get a response but here we go anyways. I have a 2006 IS250 AWD and picked up a set of Infiniti Rays 19" wheels. Given what I've read about our cars and keeping the diameter the same as oem (correct me if I'm wrong) I thought that my best bet was going to be 225/35 in the front and 235/35 in the rear. The tire shops in my area aren't staffed with all of the brightest and I don't want to risk damage to my car trusting them.
I searched this thread and found a couple answers for wheels with similar specs mostly - 19x8.5 255/35 rear & 19x8 225/35 front.
Help, please?
Help, please?
#5602
Help, please?
Help, please?
Miller (10-12-18)
#5603
Thanks! With the half inch difference in width, wouldn't I need to have different sizes for the front and the back though? that's what's giving me a headache. I've looked at the diagrams and docs explaining the circumference and percentages different from stock but I'm extremely gun shy given the horror stories I read about breaking the AWD.
I have new lugs and need to pick up the rings - probably when I get the tires. That's a good way to snap a bolt (learned the hard way on my old SC400)
#5604
Go with 235/35 on all 4 wheels.
#5605
Help, please?
Help, please?
#5606
I found a good deal on rims.
Fast FC04 18"
225/45/18 offset +35 all around
Would these fit on my 2006 is250 AWD stock height?
I currently have wheels and tires with exact same spec as stock 17s with 15mm spacers in front and 25mm spacers in rear and its pretty flush.
Fast FC04 18"
#5607
I'm using the 19" Rays that came on the up spec'd version of the G35 coupe. As seen below. I just want to make sure that I don't screw myself by not buying the right circumference tires for the rears.
#5609
R: 19x8.5+33mm offset
Imo you should be ok with 235/35 and 265/30.
