How about I go...
F: 19 x 9 +18, R: 19 x 10 +17 instead of...
F: 19 x 9.5 +24, R: 19 x 10.5 +23?
Should I go for 9 and 10 setup or 9.5 and 10.5 setup?
Thanks!
Those sets have essentially the same amount of poke. Only difference is youd have more tire/wheel width inside your fender. I'd go 9/10 or 9/10.5 just because i dont feel necessary having a wide front wheel (if your lip size is the same, like yours would be) .
How about I go...
Thanks!
for high-offset wheel specs, go with wider wheel specs to run wider tires.
for low-offset wheel specs, go with the narrower specs to run narrower tires for maximum fender-tire clearance.
I'm thinking of picking up some Varrstoen 1.1.2 lm reps cuz they are so affordable. I'm looking at
19x9.5 +22 front
19x11 +25 rear
I plan to do some fender work to get these on without rubbing. Do you think that's feasible?
Also what tire size should I be looking at for good clearance without tire stretching to an unsafe point?
Thanks!
so you're going to do all that fender work and run stretched tires on a set of replica wheels?
/OT
it's feasible, but you'll have to roll your fenders completely flat AND shave the fender tabs. and while you're getting your fenders rolled flat, you'll need to get a slight pull.
225/35-19 + 255/35-19. don't try to run anything wider unless you have a serious pull, unless you don't mind your tires and fenders meeting each other each time there's a load on your suspension.
Will these fit my IS250? I'm planning to get the car dropped by atleast 1.5" both front and back, am I going to to need spacers and fender rolling? thanks!
and I forgot to mention, these are the tires wrapped around the rims as of the moment:
Your gonna need a BMW to fit those. Cause Lexus is 5x114.3 bolt pattern.
