Will those wheels fit? START HERE.
Old Mar 29, 2011 | 09:58 PM
  #1921
projectdna's Avatar
projectdna
Originally Posted by jegz250
i jus bought my is250 a week ago and im lookin into getting 19's with some killer offset so my ? is for those who has them is whats the lowest offset and width that most guys run i know that i have to pull etc. jus really looking into offsets cause i really want my car to have a good stance thanks
what brand/model of wheels? tires? how much do you want to stretch your tires? how much fender work are you comfortable with?
i recommend looking around/searching for others' rides and then asking how you can achieve that stance.
Old Mar 30, 2011 | 06:19 AM
  #1922
Mv350's Avatar
Mv350
well if you really wanna go nuts shoot me a pm. itll take work and gotta talk about static or air. lmk what you wanna know
Old Mar 30, 2011 | 06:26 AM
  #1923
Mv350's Avatar
Mv350
Originally Posted by Vroomin350
Ive been good with the modding lately so its time to get back on track.
Trying to order some enkei nt03 right now.
18x8.5 +38
18x9.5 +27
For the front,
Looks like I will be fine up front on the rims(correct me if wrong please!), wondering..
1.If tire size 235/40/18 would be too meaty?
For the rear,
1.Will stock 255/40/18 tires be fine?
2.Will I need to roll the rear fender regardless of tire size?
235/40 should clear in the back with no mods maybe a slight roll. front is fine with 225/40
Originally Posted by lazysob
Can someone please help me out here.....Thanks!
youll be ok, no issues
Originally Posted by speedywa
hey guys i have a set of staggered wheel
19x9 +38 front 19x10 +38
if i want to go for 255/35R19 front and 275/35R19 rear
I know i might need some fender mods. How serious will it be?
I personally don't like stretched tire. So I go for this route on my setup.
Thanks
roll the fenders
Originally Posted by soulsoarer
WORK Meister S1 3P Gold 19x9.0 / 19x10.0
Front: +35mm Offset (3" Lip)
Rear: +35mm Offset (3.5" Lip)
? if you wanna know tires. 265/30 rear and 225/35 front. roll to be safe
Originally Posted by TriggrHapy
Hi All, new member and just got my new 2011 IS 350 AWD last month. Love it...except the ride hight and the 17" wheels.
Thinking of getting either an Eibach or F-sport spring set to lower the ride height and am looking at getting some Linea Corse 818s 19" x 8.5"w.
I have seen a lot of discussion on this forum on what tires to get for a staggered set-up but not much on non-staggered. Other than looks, I don't see the point in running a non-staggered set-up on an AWD system designed for non-staggered. just my opinion...
So question is what is the ideal set-up for AWD non staggered if one wants to put on 19"?
1010 tire calc. says the closest diameter to the stock 225/45/17s are
- 255/30R19 (.02% diff) or a 255/35R18 (.02 diff). but 255 is pretty thick...Would the tires be too meaty upfront? will I be getting rub? Thinking of getting the 8.5" wide rims.
Second best would be 245/30R19 at .77% diff...
thoughts, comments would be greatly appreciated
245/30 would be safer
Originally Posted by myMRMis350
I need help pls: I had an Ichiba 10mm spacers in the back with the provided extended studs, my question is, would I be ok with 15mm spacers using the studs that came with the 10mm's? I had 6-7 turns when tightening the lug nuts,is that safe enough? TIA
get 15mm spacers with studs in them.
Originally Posted by czechitout
+38 offset front and +45 offset rear
so you could fit 8.5+38 9.5+45 but idk if you actually want 10+38 and 12+45. widths of the wheels would help
Old Mar 30, 2011 | 11:02 AM
  #1924
jegz250's Avatar
jegz250
i was thinking going bags with work meisters yes i want to go nuts
Old Mar 30, 2011 | 11:35 AM
  #1925
xnfsx's Avatar
xnfsx
would i rub with these fitments?
18x9 +36 225/40/18 18x10 +36 255/35/18
Old Mar 30, 2011 | 12:14 PM
  #1926
hybridanim's Avatar
hybridanim
should be fine, front might rub a little bit depending on how low you are.
Old Mar 30, 2011 | 12:47 PM
  #1927
projectdna's Avatar
projectdna
why run 35-series tires in the rear?
reason being, oem 2is 18" rear tires are 255/40-18's...
Old Mar 30, 2011 | 12:50 PM
  #1928
xnfsx's Avatar
xnfsx
i have an awd. over diameter has to be less than 2% im running them on isp modes at the moment no check 4wd issue. Had 225/40/18 and 255/40/18 and has check 4wd issue at the beginning of the month.
Old Mar 30, 2011 | 03:51 PM
  #1929
eightysix's Avatar
eightysix
Default borbet XA
Hi,
I plan on buying these used Borbet Xa rims tomorrow.
all of them are 8,5 x 19 - ET 35 and come with tires 245-35-19
I know especially the front is not the best tire size, but can I just put them on and run them until the tires need to be replaced? Or will they rub?
(i am not lowered)
Attached Thumbnails Will those wheels fit?  START HERE.-schermafbeelding-2011-03-31-om-00.50.15.jpg
Old Mar 30, 2011 | 06:34 PM
  #1930
eightysix's Avatar
eightysix
anyone? only got until tomorrow, thankss!
Old Mar 30, 2011 | 06:58 PM
  #1931
xnfsx's Avatar
xnfsx
run 225 instead cause u might rub in the front
Old Mar 31, 2011 | 06:05 AM
  #1932
eightysix's Avatar
eightysix
the problem is they come all on 245 so i dont wanna spend money on getting new front tires already..
Old Mar 31, 2011 | 06:28 AM
  #1933
projectdna's Avatar
projectdna
"if you wanna play, you've got to pay."
Old Mar 31, 2011 | 09:16 AM
  #1934
vi3t80y's Avatar
vi3t80y
Default mrr gt5 staggered f 235/35/19 and r 275/30/19
if anyone can answer my question.i just bought this mrr gt5 staggered.here is the link http://www.elementwheels.com/proddet...85bmrrgt51995b
and i just bought a set HankookVentus V12 evo K110.here is the link for tires http://www.tirerack.com/tires/tires....ompare1=yes.im running front 235/35/19 and rear 275/30/19. my question is im running correct tires size and its not gonna rub on my fender.i hear running staggred gonna mess up my awd.Thanks if anyone can answer my question.
Old Mar 31, 2011 | 09:57 AM
  #1935
laobo979's Avatar
laobo979
You should be good but 275 30 is a meaty size if your gonna drop it. 265 30 would of been better fit.
