Will those wheels fit? START HERE.
Old Jan 15, 2011 | 12:46 PM
  #1831
bez's Avatar
bez
Will these rims fit on my 2010 is250 without rubbing? What size tires should I run to make them with with that offset. They are Concept One Executive RS-8 Matte Black Rims. Thanks.
20x8.5front-38 offset 20x10rear-38 offset
Old Jan 15, 2011 | 12:47 PM
  #1832
bez's Avatar
bez
Oh Yeah...I'm not lowered.
Old Jan 16, 2011 | 12:12 PM
  #1833
Lucky350's Avatar
Lucky350
What tire sizes would be ideal to fit these. Any other work need to be done? I have the Sport Package and will probably be lowering some more later
Volk TE37
19x8.5 +22
19x9.5 +22
Old Jan 16, 2011 | 06:32 PM
  #1834
projectdna's Avatar
projectdna
Volk TE37
19x8.5 +22
19x9.5 +22
front: 215/35-19
rear: 245/35-19
you'll need to roll your fenders and shave the fender tabs for clearance.
btw, what color? just curious.
Old Jan 17, 2011 | 10:47 AM
  #1835
Vroomin350's Avatar
Vroomin350
guys
20x9 front
20x10.5 rear
what tire sizes should I run up front, I got a slight rub when making u turn, running 275/30 rears right now.
Old Jan 17, 2011 | 12:42 PM
  #1836
Lucky350's Avatar
Lucky350
Originally Posted by projectdna
front: 215/35-19
rear: 245/35-19
If you're referring to the color of my car, it's Crystal White. The Volks will be a customer color. I have a set of TE's on my S2K. I can't seem to get away from them.
That's not stretching the tires too much right? Kansas has some potholes that sometimes look like craters.
Old Jan 17, 2011 | 01:27 PM
  #1837
projectdna's Avatar
projectdna
i was referring to the color of your TE's. i'm curious to know the custom color you have lined up for them.
regardless, excellent choice of wheels.
That's not stretching the tires too much right? Kansas has some potholes that sometimes look like craters.[/QUOTE]
as far as the recommended tire sizes, they're not much of a "stretch" (still within factory recommended wheel widths). i've got the same wheel/tire specs, and my 2is is a daily driver.
Old Jan 17, 2011 | 04:32 PM
  #1838
Lucky350's Avatar
Lucky350
as far as the recommended tire sizes, they're not much of a "stretch" (still within factory recommended wheel widths). i've got the same wheel/tire specs, and my 2is is a daily driver.[/QUOTE]
You know anyone that has some for sale?
Old Jan 18, 2011 | 03:37 PM
  #1839
aCortIS101's Avatar
aCortIS101
Question: a buddy of mine has a extra pair of tires 245-30-19 that he's willing to give me... Will these be able to fit on the front? Wheel is a 9.5" +22
Will these just rub all the time? Even with the shaved tabs... I don't see much of a stretch on these..
Thanks
Old Jan 19, 2011 | 08:34 AM
  #1840
fknISC808's Avatar
fknISC808
just wondering what tire pressures is safe on stretched tires? 35psi cold? Just so I know what to look out for. I never ran this type of setup before.
Old Jan 19, 2011 | 05:45 PM
  #1841
Lucky350's Avatar
Lucky350
19x9 +25
19x10 +35
This will be my last inquiry. Let me know what I need to do and I'll have these wheels in a few.
Old Jan 19, 2011 | 06:15 PM
  #1842
steezy's Avatar
steezy
Thanks
yeah not really stretch and yes it will rub depending how low you are.
Old Jan 19, 2011 | 06:29 PM
  #1843
Vincent123's Avatar
Vincent123
i usually run 40-45psi on stretched tires
Old Jan 20, 2011 | 09:47 AM
  #1844
fknISC808's Avatar
fknISC808
wow, thats a ways away from what I thought I should be running. Guess Ill have to air it up. Thanks!
Anyone else want to chime in so I can get an average?
Old Jan 20, 2011 | 12:19 PM
  #1845
JMcDonald's Avatar
JMcDonald
I'm running 43 all around
