How to Change the Transmission Oil in my IS250?
Old 01-19-10, 09:14 AM
Koz
Koz's Avatar
Just remember, the IS uses a special low viscosity "WS" fluid. If any other fluid is used, you WILL have issues. The only other fluid that I know of, that can be used is this;
http://www.amsoil.com/storefront/atl.aspx
Koz
Old 01-29-16, 07:12 AM
Rocknrose
Rocknrose's Avatar
Default Transmission fluid change for 2007 GS 350
I decided to change mine fluid this Saturday. There is no way the viscosity has held up. If Canadian Lexus have it in their manual to change it at 60,000 I'm certainly going to do mine with 170,000 0n it. My goal is to reach 300,000.
Old 07-29-16, 11:46 PM
pandorum
pandorum's Avatar
I changed transmission fluid and replaced the filter at 108'000km's. Oil was black watery and burnt. No way its lifetime fluid. I'm guessing by lifetime they mean 100'000km's not 300'000 plus haha. Ideally i would change every 50'000km's. Gear changes are now smooth and quick compared to before. Its such a shame they built a gearbox that has to be split open just do general maintenance. I managed to remove about 3.75 litres by removing the pan and filter then i did the same thing again about a week later. I'm going to do this once a year now that i know how easy it is to do.
Old 08-05-16, 09:18 PM
SoleKing
SoleKing's Avatar
So I have a 08 is350 with 108k miles, I've been reading the threads and seeing that every1 says it's best not to do a trans flush, but really what is the cons to going through with it (and not through the dealership).
Old 08-06-16, 04:03 AM
Rocknrose
Rocknrose's Avatar
Default Transmission fluid replace & refill.
I had a mechanic drain the pan (2.75 qts) and with a hand pump he refilled 2.75 qts. This was done 3 different times. I now have 189000 miles and my gs 350 is running fine.
Old 08-06-16, 09:42 PM
Gs3500
Gs3500's Avatar
The GS forum has a guy who did a GREAT write up with pictures of his DIY. Check it out!
Old 08-06-16, 11:35 PM
SoleKing
SoleKing's Avatar
Can u post the link to the DIY...
Old 02-26-18, 06:34 AM
cheerio3
cheerio3's Avatar
At my oil change, I did a transmission drain and fill on my lexus is250, 180,000 miles. It drained out 4 quarts and I replaced 4 quarts. All fluid was black and burnt. At my next oil change, would you recommend draining 4 quarts transmission fluid again?
Old 02-26-18, 09:25 AM
MikeFig82
MikeFig82's Avatar
I did the same as you. It took me about 3 times to see the oil red again. I have the AWD though. I'm not sure which you have.
Old 02-27-18, 08:07 PM
Rocknrose
Rocknrose's Avatar
Definitely since it was black and burnt. The manual claims lifetime transmission fluid so I would say you make the choice. I have had mine done at least 4 times and I have 207,500 miles.
Old 05-15-18, 03:39 PM
frotiss
frotiss's Avatar
Hey can anyone help me with info to change my Transmission fluid on my 2006 IS250 Thanks
Old 05-16-18, 01:47 PM
Gville350
Gville350's Avatar
Old 05-16-18, 03:12 PM
XSV
XSV's Avatar
I found the drain and fill method wasn't accurate, so I went ahead and did the drain, over fill, and drain at operating temp.
Old 05-16-18, 03:13 PM
Zynthe
Zynthe's Avatar
I see lots of posts about the auto tranny, but what about the 6spd tranny?
I have a 6spd and I want to change the transmission fluid since like others have said, nothing is lifetime. Is it the same process as the autos where I have to just drain and fill?
Old 11-08-18, 09:35 AM
chenderson
chenderson's Avatar
Default *THE* VIDEO for Toyota / Lexus Sealed WS Transmission Fluid Change
Toyota / Lexus Sealed WS Transmission Fluid Change:
Quick Reply: How to Change the Transmission Oil in my IS250?
