Toyota Considering 2nd Generation IS Accelerator Replacement
Old Nov 30, 2009 | 09:47 PM
  #76
HaveBlue's Avatar
HaveBlue
The new mats sound great. My All Weather ones started to fall apart shortly after I bought them. Not sure about the brake interlock. I already have a VDIM defeat module wired into the brakes. They aren't going to like that!
Old Dec 8, 2009 | 07:19 AM
  #77
cajun's Avatar
cajun
Apparently, the dealership was informed of the accelerator pedal issue prior to the accident:
http://www.signonsandiego.com/news/2...h-had-earlier/
Old Dec 8, 2009 | 07:44 AM
  #78
Kurtz's Avatar
Kurtz
So yeah... stupid dealership using the flootmats from the wrong car, that ignored complaints about it, combined with a driver too dumb to put the car in neutral, and now Toyota's out eleventy-pepsi dollars on a totally unnecessary recall.
Old Dec 8, 2009 | 08:19 AM
  #79
Evitzee's Avatar
Evitzee
Yep, that pretty well sums it up. There is no fault with the setup as long as the correct mats are used and are hooked in correctly. But that wasn't good enough for the authorities, and Toyota felt that had to do 'something', so let's shave the gas pedal and provide some new style floormats. Voila, we are good corporate citizens and we solved the problem. It's all BS. I have less admiration for Toyota after this debacle.
Old Dec 8, 2009 | 04:58 PM
  #80
15951's Avatar
15951
According to the police report, the police interviewed several previous drivers of the car (it was a loaner) and asked if any of them knew that holding the ignition button for three seconds would shut the car down, and none knew.
One of the previous drivers had the same problem, and pumped the button a few times before using neutral.
I predict that 2012+ model year Lexus vehicles will shut off with 3+ rapid presses of the ignition button.
Old Dec 9, 2009 | 11:23 AM
  #81
cajun's Avatar
cajun
Not certain if Toyota having 41% of all sudden-acceleration complaints is related to their pedal-related recall:
http://blogs.consumerreports.org/car...s-ford-gm.html
Old Dec 9, 2009 | 11:39 AM
  #82
GiantsFan's Avatar
GiantsFan
Ok...i just checked on my car... There is NO possible way for the pedal to get stuck!! I will let my dealer know not to touch my pedal... If they do, thy are buying me a new one.
Old Dec 9, 2009 | 03:57 PM
  #83
juice14's Avatar
juice14
Couldnt believe the floor mat thing, you have to be what? like 1 year old to not be able to clip the floor mats properly?
Old Dec 9, 2009 | 04:12 PM
  #84
15951's Avatar
15951
The accident happened on a loaner that had RX mats in an ES. They didn't fit properly. Read the police report, above, and you'll have a different perspective on this. I know I did.
Old Dec 9, 2009 | 05:02 PM
  #85
Kurtz's Avatar
Kurtz
Yeah, can't really blame the driver for the mats.
You can blame him for not putting the car in neutral though
Old Dec 9, 2009 | 05:10 PM
  #86
15951's Avatar
15951
I thought about this. I'm wondering if the guy slapped it into park in a panic, and the car just kept on going. I remember a thread on here discussing how "park" keeps the car in "drive" to keep from killing the transmission.
At one point in the police report, it's discussed that the car pulled over to the side of the road at one point and was going slow until there was smoke at the front of the vehicle and he sped off. The smoke was presumably the brakes failing, and I can just imagine this guy slamming the thing into park when he was on the side of the road and not being able to stop.
Agreed that neutral would have been a better course of action, but I can certainly understand how this could happen after reading the report. We're all armchair experts, but the guy was panicked and probably not thinking very clearly.
Old Dec 9, 2009 | 05:15 PM
  #87
IS-SV's Avatar
IS-SV
btw - Anybody seen a sawed-off by dealer gas pedal or hopefully that never happened?
Old Dec 9, 2009 | 07:05 PM
  #88
lobuxracer's Avatar
lobuxracer
Tech Resource
There's a fundamental problem with this. The engine does not load in park. Ever. So saying he shredded the parking pawls and the car continued to drive because the transmission is in "drive" and park at the same time makes no sense. The valve body solenoids on the gearbox determine what gear is active. In park, none of the solenoids are actuated, so there's nothing in the gearbox to provide a driving force to the wheels.
Wouldn't it be bizarre if this were related to the ES350's transmission flare problem, and there really was a major internal failure in the gearbox?
Old Dec 21, 2009 | 07:15 AM
  #89
cajun's Avatar
cajun
The 'fix' appears to be more involved than necessary:
http://www.autoblog.com/2009/12/18/c...medy-detailed/
Old Dec 21, 2009 | 07:35 AM
  #90
IS-SV's Avatar
IS-SV
The fix/hack job is something that I will avoid, I guess the new pedals are available in April...
Akachan LS
Nov 18, 2013 05:41 AM
pagemaster
Mar 11, 2010 11:42 AM
is250gurl
Feb 7, 2010 03:44 PM
jruhi4
Apr 24, 2009 02:21 PM
