awd or rwd
If you crawl underneath the front, the plastic shield over the oil filter will say IS4WD. Also if you look at the front suspension, there will be an axle(it has big CV boots) attached to the front wheels, along with the steering linkage. Also the AWD has a bigger turning circle 36ft vs 32ft.
Welcome to CL
I'd say you've got a good set of responses. I found this thread for you that might also be of some interest.
https://www.clublexus.com/forums/is-...w-to-tell.html
