Rear GFX lip gaps...
Old 10-08-09, 01:59 PM
w1ck3d64
w1ck3d64's Avatar
Default Rear GFX lip gaps... BEWARE OF CARTECH AUTOBODY in TORONTO
Hi all,
I just had my GFX rear installed on my 06 IS350. I noticed gaps around the rear sides (about half a cm). I talked to the guy and he said he tried everything to get the gap small. He said that this could be because since the car aged, so has the plastic so the fitment might not be perfect.
Can anyone chime in on this? Do you think I can buy some double sided tape and put it in the gap to try and close it? What's the recommended double sided tape?
thanks!
Old 10-08-09, 03:11 PM
fasteddy91
fasteddy91's Avatar
Who installed it? Did they cut the exhaust openings in your bumper? You may need to do this in order to fit properly.
BTW, who is "the guy"?
dojoman
dojoman's Avatar
I have the same gap especially on the curve corner. I think it's normal, more tapes would help but I don't even notice it that much or care about it anymore.
Old 10-08-09, 03:19 PM
w1ck3d64
w1ck3d64's Avatar
oh the guy who installed it for me haha
http://www.canadiantire.ca/AST/brows...ing%2BTape.jsp
would this be the one? i'm just going to use some forceps to stick it into the gap and PUSH lol
Old 10-08-09, 03:20 PM
fasteddy91
fasteddy91's Avatar
so, did he cut the openings?
Old 10-08-09, 03:33 PM
w1ck3d64
w1ck3d64's Avatar
yeha it's cut and drilled
Old 10-08-09, 03:36 PM
fasteddy91
fasteddy91's Avatar
hmmm, it sounds like the guy didn't install it properly.
Old 10-08-09, 03:44 PM
w1ck3d64
w1ck3d64's Avatar
well the back is perfectly fine...it's just the rounded sides...he's pretty reputable in my area and has done a lof of GFX rears but in any case...i hope the tape will fix it...seems like it would...that lexus double sided tape that comes with it SUCKS
Old 10-08-09, 03:49 PM
305is350
305is350's Avatar
I installed mine myself following the instructions, and it's perfect no gaps around, so double check with the install.
Old 10-08-09, 04:28 PM
fasteddy91
fasteddy91's Avatar
if the guy installs the lip ever so slightly off, then you will get the gap. I would uninstall and reinstall again. I bet that will fix your problem.
Old 10-08-09, 04:59 PM
J250
J250's Avatar
Bingo!..
You have to reinstall the kit. It was not properly installed... Tell him to follow exactly how the instruction shows and before tightening the bolts, it must be perfectly aligned. The kit does not have any gap whatsoever.. I had to reinstall mine twice to get it perfect And lol noway the plastic can age like that and give that big of a gap difference....
Old 10-08-09, 05:17 PM
w1ck3d64
w1ck3d64's Avatar
Originally Posted by Muggy
Bingo!..
yeah eh? so i should bring it back? if the tape i posted up top will fix it i dont really care i guess..so the plastic warping is BS?
Old 10-08-09, 05:28 PM
600rr05
600rr05's Avatar
i had my GFX rear kit put on just this year and my car is a 06 no gaps at all. If adding more tape works for you go for it but just remember tape can only hold on so long.
Old 10-08-09, 06:04 PM
w1ck3d64
w1ck3d64's Avatar
hmm thanks for the responses...looks like i'm giving that guy another visit
Old 10-08-09, 06:12 PM
Wisdom
Wisdom's Avatar
I agree..
You may need to retape it anyways if you're taking the lip off
Quick Reply: Rear GFX lip gaps...
