Staggered setup on AWD ! - The Mother Thread - !
Hello everyone
This is an awesome thread for all AWD enthusiasts.
- What is your exact wheel/tire setup ?
Front
Tires Invo 225/40-18
Wheels IS350 18"X8"
Rear
Tires Invo 255/40-18
Wheels IS350 18"X8.5"
- How many miles you've been running this for ?
Just installed them less then 50 miles
- Are you noticing any issues (gas millage ect...)
Not yet
- Also post your general thoughts/comments
lowered with Hotchkis springs
I was really nervous about putting these on until I found this thread. Thank you. I think my car looks awesome and does yours.
Front
Wheels IS350 18"X8"
Rear
Not yet
For anyone who have ran or know someone who ran
19/35/225 Front 19x8.5
19/35/245 Rear 19x10
Was there any major problems with this setup? I was planing on running this setup for a little stretch in the rear and was concerned if this was going to mess anything up. I put this into the 1010 tire calculator and the rear difference is about 3.03. Is that a big difference or should it be fine? Any input would Help !
Hey guys, I just ordered some Concept one rs-8's with the following specs:
19x8.5 - 38mm (f)
19x10.5 45mm (r)
I do realize i will have to do some fender mods. I was wondering what tires i should run to have the closest rolling diameter. I used 10/10 tire calculator but Im not sure about tire stretching etc. I really appreciate it, im going to buy tires based on your advise most likely.
I know I can run 225/35 front s but What do you recommend for the rear? 255/35 or 265/30? I think 255 is closer to diameter but doesnt that mean more stretch? Im trying to stretch the tires as least as possible
19x8.5 - 38mm (f)
19x10.5 45mm (r)
That way to wide to go up front. Your best bet is to run 19x9.5 up front and 19x10.5 rear. Ive seen the 19x11 fit but you gonna need a good shop to pull the fender or more to fit it.
i would like to reduce the gap between my fender and my tires on the back maybe on the front also but its not too bad
here is my set up
is 250 awd
rims
19x8.5 offset +35 front
19x9.5 offset +38 back
tire
front 225/35/19
back255/30/19
lowering spring h&r awd (11/4 inches drop)
Question is can i put 265/30/19 to reduce the gap without rubbing, will it make a difference
if not what can i put?? will i have tochange the front tire also???
with this set up the car is wobbling when i start until 50mph.
is it in 1% tolerance?
here is my set up
is 250 awd
rims
tire
front 225/35/19
back255/30/19
