LED Interior Lighting Kit
i ordered LED Interior Lighting Kit from Sewell Lexus around end of march, and i didnt have anytime to install them so i put them in the trunks. so i tried to install them today starting with the led door lights. i plugged in the lights and it wouldnt come on.. could it be possible that i did something wrong or since i left the lights in the trunk for long time is it broken? :cry:
Unless the LED's got crushed or you spilled something on them they should be fine. Heat buildup in the drunk should not effect the LED's if thats what your worried about.
Try turning the LED's around the other way, you might have the contact points reversed. |
is there DIY for the lights?
I isntalled these a while back and some of the lights would not light b/c they were on backwards.
you cant install the door lights backwards... it doesnt fit it only fits one way.. or im just too noob and stupid to install it loll
Can you be installing them in the wrong door?? which will cause you to be installing them backwards?
uh i dont think they have sides and.. i also tried switching them but i have no luck... FML
hey odj1989. when i got my led lights from sewell every light turned on except the right passenger clear led light. I thought it was a defective part, but it was not.
The passenger light part with the led light in the middle is composed of 2 pieces. you have to sepearte the 2 pieces, pull out the led bulb, rotate the bulb 180 degrees n stick it back into the light piece. the bulb was some how reversed when they shipped it to me. It worked out for me and hope this helps. let us know what happens. |
thanks for the info! i will try this
Originally Posted by S to the K
(Post 4820741)
Originally Posted by funnie
(Post 4821755)
umm.. how do you open the front and back light cover to get the light bulb changed.
do a search or check the sticky for DIY.
Originally Posted by odj1989
(Post 4879837)
its pretty simple .. theres a lighting thread around here.. 5 mins to do front and back..
