My HID Fog Projector Retro
Old 05-31-09, 03:29 PM
ELL Y
ELL Y's Avatar
Default My HID Fog Projector Retro
So with the end of this semester of school, and inspired by other fog retros on this forum, I decided to do one of my own.
Thanks to Tchan1 for his own very informative HID Fog retro thread (Which helped me tremendously as well as provided me inspiration for this project), 100Plus for his awesome knowledge of bumper removal techniques, and Nabbun for just bumming around, hahaha
Parts Used:
Fog lights
2000 Grit Sandpaper
Some Car polishes and a hand polishing pad
Black Spraypaint
JB Weld
H3 Bosch Mini projectors
-Their output is pretty acceptable for fogs:
DDMTuning H3 HID kit in 4500k
ACE brand Plumbing flanges
L Brackets
Total Cost: ~$160.00
So first thing you want to do is remove the bumper. The fog lights are right behind it. Disconnect the fog wiring (Bulb connection to harness on both sides as well as another connection on the driver side fog only)
The actual fog is held on by one 10 mm bolt, and then you just slide it out of the clips (both shown at the top in this picture). There might be another clip somewhere which you can easily remove
Next, preheat your oven to 275 degrees. Place one fog light in and let it bake for approximately 5 to 10 minutes at this temperature. Remove the lamp. Loosen the clips at the top and bottom of the fog with a small screwdriver, and then pry apart with your hands.
OPTIONAL NEXT STEP:
My lens were worn out and pitted, so I polished them. Get some soapy dishwashing detergent dishwasher water and 2000 grit sandpaper. Sand the entire surface, being sure that the soapy water is generously applied.
It'll look like this:
Then, I used an intermediate abrasive swirl remover/polish with an orange pad and polished the hell out of it. Following that, I used a light swirl removal to get the lens clear again.
Meanwhile, I painted the whole thing black and used JB weld to mount the shrouds, which fit PERFECTLY.
I dremeled the back of the original reflector out, and mounted the projector in it with L brackets. Rather than removing the entire original reflector piece, I chose to just remove parts of it so that I can retain the stock vertical adjustment that is built into it.
I used some JB weld to help keep the screws tight and the projectors rock solid, then sealed up the entire unit. Same thing here- bake them at 275 for 5 minutes, then put the pieces back together with some clips/ C-clamps.
The back of the unit still had some space that I had to seal from moisture and the elements,
so I used some double sided tape to help keep them out
^ Kind of ghetto, but didn't see any other readily available options.
Take off the bumper, put the fogs back in, and wire up the fog HIDs (mount the ballasts behind the metal bumper support)
Use a cable tie or some other method to keep the wires tidy, then put the bumper back on.
Before and After
Matches my headlight retrofit quite well:
Just the fog lights alone on the wall:
I had to take the pictures pretty close because these are fogs and they're pretty low.
Just headlights on (SC430/E30 55w)
Both on
As you can see, the color does not match perfectly. This is due to the age of my headlight bulbs, as well as the inherent inaccuracy of the color temperature of the kit bulbs in my fogs. I'm still happy with it, because at least I do not toss up glare now. Having said that, I will almost never actually turn on these fog lights, since there's really few reasons which call for their use.
Thanks for looking
Old 05-31-09, 03:33 PM
love67
love67's Avatar
very nice!!! i like it!
Old 05-31-09, 03:45 PM
acefalcon2
acefalcon2's Avatar
should paint your Headlights too to match and it'll look so AWESOME!!
Old 05-31-09, 04:11 PM
nabbun
nabbun's Avatar
he did lol
thanks for the shout out and can't wait for the night shots!
Old 05-31-09, 05:27 PM
Tchan1
Tchan1's Avatar
Hey nice retro now we have the same set up once again! lol. I am about to do another project with the fogs too. It has something to do with LEDs, but you will see when I am done. Just waiting for some parts to come in.
Old 05-31-09, 05:30 PM
Tchan1
Tchan1's Avatar
Ell y, did you use the regular size H3 bulbs or the H3c mini bulbs? If you used the regular ones did you space it out so that you can get a better output?
Old 05-31-09, 05:42 PM
rule1223
rule1223's Avatar
nice man! and your roof spoiler will be there next week!
Old 05-31-09, 06:41 PM
GS3T
GS3T's Avatar
well done...
Old 05-31-09, 06:45 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
now get out there and test them out!!!
Old 05-31-09, 08:04 PM
ELL Y
ELL Y's Avatar
Hehe yeah. They're actually already painted black.
Yeah Tommy. You're getting too hardcore with these lighting things- I gotta stop jocking your ******. But of course, do tell me what you've got in the works haha
I also used H3 bulbs, which I spaced to match the focal point of the H3Cs (H3 are actually VERY close to the H3C in terms of output, which I have tested as well - thanks Nabbun for letting me test your bulbs)
Already have. Updated some pics. However, I went into this project fully knowing that I'd have little to no improvement in terms of visibility for regular driving, and it's certainly good that I didn't keep my hopes up with that respect.
For the others, thanks for the compliments, and I appreciate any criticisms, etc
Old 05-31-09, 08:06 PM
Batmobile
Batmobile's Avatar
Old 05-31-09, 11:33 PM
Tchan1
Tchan1's Avatar
Don't worry I will have another DIY thread when I am finished. It is fairly easy to do.
Old 06-01-09, 07:36 AM
AS~IS
AS~IS's Avatar
Very nice...
Loving your crazy retrofits lol! Props to you!
Old 06-01-09, 02:41 PM
A/C
A/C's Avatar
awesome
thumbs up man
Old 06-01-09, 03:10 PM
mikez
mikez's Avatar
I feel so left out, should of ordered some chinese take out man lol.
I spot nabbun's puma's in the before pic.
Quick Reply: My HID Fog Projector Retro
