Hi, my name is Brandon and I'm an alc...err, I mean IS owner.
#31
First of all, I still can't figure out the Homelink buttons after reading all the threads. I got the button to rapidly blink with the remote and then hit the learn button on the Genie and tried to link them but it doesn't seem to link at all. I mean, I've hooked every car up successfully and do all my own mechanical work but maybe I'm a retard...still reading.
In brief use the Lexus manual for programming the transmitter in the car and use the garage door manual for programming the car to the door.
What I did:
1) Open garage door with the door transmitter.
2) Drive a couple of blocks away (so the transmitter will not reach the door) and program a button on your mirror using the Lexus manual instructions
3) Then go back home and follow the door opener manual instructions (basically push the button on the back of the door opener then go to car and push the button on your mirror that you already programmed til the door opener light blinks)
4) Your done.
Good Luck
Larry
PS you may also, before you start the above, want to reset your homelink by holding buttons 1 and 3 at the same time for 20 secs. Just a thought.
