DIY Changing Stock HID Bulbs
Old 09-19-12, 07:15 AM
  #61
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
does the side that uses the D4S bulb have a moving projector that functions?
Steve
Old 09-24-12, 03:35 AM
  #62
ZNation
ZNation's Avatar
Originally Posted by XenonDepot
Hi,
Steve
Yes it does...And I believe the connector is not working now, I put a new bulb in to see if it would work as a temp fix, and still no light...unless a fuse is blown out which is the next thing i need to check...
Old 10-12-12, 07:25 PM
  #63
sjgIS350
sjgIS350's Avatar
Default Very easy!
took me about 40 minutes..which included cleaning the air box since I had it out. Basic mechanical skills and its a snap. A note..the bolt to remove the washer filler hose is on the top (near the filler cap) not at the bottom.
I haven't had the 'check' light issue, but have only started the car so far (no driving) I wonder if disconnecting the battery before doing the work would prevent the light?
Also, I started on the driver side as it only involved removing the washer filler tube..its actually harder to do the bulb change on the driver side than the passenger side..although removing the air box is a bit more work.but still really easy.
Old 03-17-13, 01:10 PM
  #64
NimaM
NimaM's Avatar
Excellent DIY. Thank you! Took about an hour to replace both bulbs.
Old 03-31-13, 01:29 PM
  #65
mycholly
mycholly's Avatar
hey fellas, just stumble upon this page because my driver side low beam headlight just "went out". i quote that term because the driver side light actually turn on but a couple minutes later it turn off by itself. The only way to get it turn on again is by turning the light off then turn it on again. So my question is, is it the light bulb problem? or could it be something else? Any help will be greatly appreciated. Thanks guys! By the way my car is a 2008 lexus is250 AWD.
Old 03-31-13, 02:38 PM
  #66
NimaM
NimaM's Avatar
Most likely it's the bulb.
Old 04-01-13, 10:31 AM
  #67
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
If you want to be certain you can swap your bulbs left to right to see if you can isolate whether the problem is a result of bad bulb or ballast.
Steve
Old 04-08-13, 09:55 AM
  #68
mycholly
mycholly's Avatar
Yeah it was the bulb! Lol it was surprisingly easy to swap as well. Thanks for the inputs guys!
Old 04-08-13, 10:00 AM
  #69
XenonDepot
Former Sponsor
XenonDepot's Avatar
No Problem. I figured that you will need to know how to swap out the bulb at some point so you may as well make sure you are getting the component that will fix the issue.
Old 09-29-13, 01:30 PM
  #70
Ca1vN
Ca1vN's Avatar
Hey guys I just changed the bulbs. Now the day time lights aren't on when its at auto. But turns on when I have it at the on position. When the car is off the lights at on mode it makes a whining noise. Help me please! Thanks all
Old 09-30-13, 08:19 AM
  #71
XenonDepot
Former Sponsor
XenonDepot's Avatar
Ca1vN: What bulb did you change, and what did you change it with?
Steve
Old 09-30-13, 11:33 AM
  #72
Ca1vN
Ca1vN's Avatar
Steve
i bought it from amazon.com toshiba harrisons, the only problem i have now is when i have the engine off the car makes a whinning noise its not very loud, but you can hear it. the bulbs are the stock ones. i just googled oem and amazon had them.
Old 09-30-13, 07:43 PM
  #73
Ca1vN
Ca1vN's Avatar
http://www.amazon.com/2008-Lexus-IS2...UTF8&carId=001
this is what i got back in april and i just replaced them.
Old 12-03-13, 02:57 PM
  #74
92fs
92fs's Avatar
I used this DIY and it worked perfectly! I got my D4S bulbs from KBcarstuff on sale and are awesome! Thanks again!
Old 12-03-13, 02:59 PM
  #75
XenonDepot
Former Sponsor
XenonDepot's Avatar
Sweet! Which D4S HID bulbs did you get?
Steve
Quick Reply: DIY Changing Stock HID Bulbs
