Here is my set of Volk's on my G35 I just traded in.
19 x 8.5 +23 on 245/35
19 x 9.5 +24 on 275/30
I would like to put these on my IS250 AWD. What tire sizes would you guys recommend for those offsets?
For AWD, run the diameter as close as possible, run 235/35 at the front and you'll be good Originally Posted by crazy8ship
Quote:
If you look at his offset he might be rubbing with those tires. Plus being awd using mix match used tires is a no for awd. Must be new same pattern and tread depth.Originally Posted by IS250TW
Quote:
19x9.5 +22Originally Posted by static250
Your setup is perfection! What are the wheel/tire specs?
19x10.5 +22
Hankook V12s 225/35 & 255/35
Quote:
Hey bro , i hve few question about your wheels set up . Would you mind if i ask you by txt ( lil faster & notification ) Originally Posted by kchow510
19x9.5 +22 19x10.5 +22 Hankook V12s 225/35 & 255/35
My # 6266888590
Thanks
Quote:
My # 6266888590
Thanks
I can only text people with iMsg. My phone is trippy. If you don't have that then just ask here or PM me.Originally Posted by Leowaxx
Hey bro , i hve few question about your wheels set up . Would you mind if i ask you by txt ( lil faster & notification ) My # 6266888590
Thanks
Quote:
Yes i can do iMsge from iphone . PlzOriginally Posted by kchow510
Quote:
I sent a text but it's not going thru. Is that the right number?Originally Posted by Leowaxx
Quote:
-6 in the rears.Originally Posted by ohiois350
Nice set up, do u run on negative camber?
