help please!!
Old Aug 30, 2008 | 05:16 PM
plusone's Avatar
plusone
Default help please!!
Well i finally found out that my right front rim was horribly cambered and it ate away all my inner threads to bare wire.. so i went to go get some new front tires. now wrapped in nittos. my car began to swerve to the right a little bit..so i went to go get a car alignment and of coarse on the IS they can only adjust the toe and the caster? but toe was readjusted but they said my caster was pushed out or something but nothing seemed bent. so fellow CL PROS what is your suggestion for my my car bear rights.
Old Aug 30, 2008 | 05:26 PM
sktn77a's Avatar
sktn77a
If your front camber on one side only is that far off, something's wrong and needs to be fixed. Get the alignment numbers from the alignment shop and take the car to the dealer. As a rule, with alignment as far off as you say it is, it's pretty easy to see the damaged suspension part.
1NSIGHT
May 13, 2019 04:07 PM
HAiS250
Suspension and Brakes
17
May 6, 2012 11:50 PM
aznpapaya
Dec 21, 2009 07:03 AM
blueridge
RX - 1st Gen (1999-2003)
Aug 27, 2009 01:52 PM
aspguru
Mar 5, 2006 12:09 PM
