ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   Power Windows won't work (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/361885-power-windows-wont-work.html)
VTLexus Jun 17, 2008 06:56 PM
I unplugged my battery a handful of times this weekend to do a stereo install, now i can't roll my passenger and two rear windows down from the driver's seat. the other windows do go down from their own doors.
anyone know how to fix this?
Cali2is Jun 17, 2008 07:13 PM
Use the controls at each window to roll all the way down and back up... This will reset driver controls back to normal.
VTLexus Jun 17, 2008 07:27 PM
any insight as to why this happens?
steedis250 Jun 17, 2008 07:36 PM
It's in the manual. You need to "program" the length of the window travel because the windows are "full auto".
plusone Jun 17, 2008 09:29 PM
same thing happend to mine when i installed the intake.. i check every fuse under the car.. what a waste of time.. should of went to clublexus for help as always!
PaPaHoFF Jun 17, 2008 09:31 PM
Happened to me as well. I just got nervous and tested the back windows on accident and played with it till it worked lol. Shoulda read the manual I see.
ISF_GG Jun 17, 2008 09:33 PM
You've got that right! CL is an amazing resource for virtually anything about our cars! :thumbup:
Gernby Jun 18, 2008 07:13 AM
The manual is an even better resource for things like this.
jns350 Jun 18, 2008 09:25 AM
Here is the procedure if you tossed your book away
Any time the battery terminal has been disconnected, initialize each door's power window after reconnecting the battery terminal.
1. Push the engine switch to select the Procedure "IG-ON" mode.
At this time, the driver's door power window switch illumination blinks.
NOTE: When the battery terminal has been disconnected, each door's power window switch illumination blinks.
2. Push the driver's door power window switch and lower the window halfway.
NOTE: When the battery terminal has been disconnected, push each door's power window switch and lower the window halfway.
3. Pull up the driver's door power window switch until the window closes, and hold it for more then one second.
4. Check for the proper operation of the "one-touch open and close" function by fully pushing the switch "DOWN" once and fully pulling the switch "UP" once.
NOTE: Jam protection function is enabled through the above initialization procedure.
