Tire Change - Navigation Problems
Old May 15, 2008 | 10:18 AM
vanduse1's Avatar
vanduse1
Default Tire Change - Navigation Problems
I just got a new set of front tires on yesterday and now my navigation seems to be inaccurate. I have gone into the menu and tried to callabrate it. I chose the option that I put on new tires and it still seems to be off. Does anyone have any suggestions or have the proper procedure to follow after a tire change?
Old May 15, 2008 | 11:50 AM
Bichon's Avatar
Bichon
Is the "GPS" indicator under the map scale present?
Old May 15, 2008 | 01:52 PM
vanduse1's Avatar
vanduse1
I guess I am not sure. I will have to look on my way home. I don't know how changing the tires could have affected whether my car is getting a GPS signal. I do know it takes tire rotation into account so I would assume that is where it is off.
Old May 15, 2008 | 02:27 PM
Bichon's Avatar
Bichon
Changing the tires wouldn't affect whether you are getting a good signal, but I believe that a good signal is required for successful completion of the calibration.
Old May 15, 2008 | 02:33 PM
vanduse1's Avatar
vanduse1
When I choose the changed tires option the screen says entering calibration mode but then doesn't every do anything after that. Should it give more input or let me know when calibration is complete?
Old May 15, 2008 | 03:47 PM
devanaire0's Avatar
devanaire0
Addendum to the first question:
Does getting larger wheels...say, an upgrade from 17' to 19' wheels alter the navigation? And if so, how do you fix that?
Old May 15, 2008 | 04:07 PM
DRivera250's Avatar
DRivera250
it shouldn't affect the GPS? i would talk it to the dealer and have them work it out.
Old May 15, 2008 | 05:14 PM
Bichon's Avatar
Bichon
The calibration that is done after a tire change tells the navigation system to recalculate how far forward the car moves during each rotation of the tire. This information (along with data from the yaw sensor), allows it to continue to show your position on the map even when it can't get a valid GPS signal, using dead reckoning.
After selecting recalibration after a tire change, it neither asks for more input nor tells you when it's done.
Old May 15, 2008 | 06:40 PM
passnu2's Avatar
passnu2
so is it always changing? How much of a difference does it really make if you never calibrate it??
I was not aware of this on our car if that is true.
Old May 16, 2008 | 09:57 AM
vanduse1's Avatar
vanduse1
After I drove it again last night I noticed that the GPS indicator was NOT there. So, it seems that something has happend to my GPS unit. I set an appoitment on Monday morning to have at it looked at.
Old May 16, 2008 | 12:07 PM
myculito's Avatar
myculito
CL Folding 500,000
Changing wheels wont' affect your navigation...what it would affect is your speedometer.
Learned this on my S2000 after putting on slightly larger wheels. The speedo had me at 2MPH slower than what my Garmin Nuvi GPS had me at.
Old May 16, 2008 | 12:29 PM
passnu2's Avatar
passnu2
i think its the opposite? I thought larger tires you where going quicker then the OD displayed? smaller tires would make you slower then what your going?? right
Old May 20, 2008 | 05:49 AM
Keith13b's Avatar
Keith13b
Thats exactly what he said. His Garmin showed him faster since he had larger tires - translation - his OD showed him slower than actual. The Smaller tires do the exact opposite. You go slower but you OD shows faster.
I, too, use my Garmin to compare speedo issues with aftermarket tire sizes. Its always good to know.
carid
Club Lexus Vendor Marketplace
Jan 31, 2019 07:18 AM
Jun 25, 2018 05:37 AM
Leonard15
Dec 11, 2010 01:26 AM
relaxfoo
Feb 7, 2010 09:08 AM
ssmoked
Sep 1, 2006 09:35 PM
