Problem connecting iphone's bluetooth
Old Apr 21, 2008 | 10:57 AM
freqfly's Avatar
freqfly
Default Problem connecting iphone's bluetooth
I've tried several times and cannot seem to get it connected to my IS. My buddy tried his phone as well and got nothing. Anybody else ever have this problem? Thanks all ~~freq~~
Old Apr 21, 2008 | 11:46 AM
SpaceCadet's Avatar
SpaceCadet
please reply with the exact steps you took to make a connection
Old Apr 21, 2008 | 11:54 AM
sincityIS's Avatar
sincityIS
I have not had a phone that worked better than my iPhone, it has had 6 months of flawless connecting.
Old Apr 21, 2008 | 01:12 PM
Brian231's Avatar
Brian231
There is a hack for the nav if you turn the headlights on and off a couple of times. Then you have to select the bluetooth icon from the main nav menu. This is a small access screen that the dealer will perform in order to get the Bluetooth working. You basically have to select a higher setting range (I think from 3 to 4). This was shown to me yesterday by member Angelo. I think there is a thread for this.
Old Apr 21, 2008 | 01:38 PM
freqfly's Avatar
freqfly
I make my iphone "discoverable", go into the telephone on the nav, select settings then bluetooth, and have it search for my phone. My phone detects my car but when I click on pair, the nav screen imdediately tells me the connection failed.
Old Apr 21, 2008 | 01:40 PM
Little E's Avatar
Little E
First of all, make sure your bluetooth is on (ON MODE) on your phone...and keep it on continuously. The nav has to connect with the blue tooth in your phone. There's a code you have to use (should be in the Navigation manual).
Old Apr 21, 2008 | 01:41 PM
freqfly's Avatar
freqfly
It is on, my phone detects the car. It just wont make the connection.
Old Apr 21, 2008 | 01:57 PM
Little E's Avatar
Little E
Yeah, it took my phone a while to connect too. The night I purchased my car, the dealership couldn't even get it to connect. Maybe it's your phone carrier?
Old Apr 21, 2008 | 05:11 PM
ek9vboi's Avatar
ek9vboi
Mine works perfectly fine. Its unlocked and I am using it on t-mo.
Old Apr 21, 2008 | 07:44 PM
GSdriven's Avatar
GSdriven
I used to have problems with my pda phone pairing but try this trick. The guy at the dealership showed me. When your phone is pairing with the car call your cell phone either from your home phone or friends phone. The car recognizes the phone right away. I hope this helps.
Old Apr 21, 2008 | 10:05 PM
vistorQ's Avatar
vistorQ
i use the iphone everyday with a hitch. but when i first started it did take a while for it to connect. i had to do it several times and u phone to make the phone the default user so it will connect automatically.
Old Apr 22, 2008 | 05:26 AM
l3lkis250's Avatar
l3lkis250
have you tried the reverse of what you did? Nav first and than iphone bluetooth next. I did that with mine and it connected no problem. My iphone asked me to put in a code so I put 1111 and than I put that code into the navi and it all connected. Its a unlocked Iphone using Rogers wireless.
Old Apr 22, 2008 | 06:39 AM
100plus's Avatar
100plus
I have a strange problem with my BlueTeeth. My phone (motorola Q) has BT on, and my car is on autoconnect. Problem is, it just doesnt want to connect. I have to re-register it every time i get into my car. Whats the deal here?
Old Apr 22, 2008 | 06:43 AM
suorum's Avatar
suorum
It seems that the only part you are missing on your set up is the CODE. it should be 1111, so you can grant the access to the phone (that code needs to be typed on your iPhone!!)
Mine has been working since the first minute I bought the car.
Old Apr 22, 2008 | 06:51 AM
Electric's Avatar
Electric
I pretty much never have a problem connecting with my iPhone. The only time it wont is if I turn the bluetooth setting on my phone off, then back on. I have to turn off the car and turn it back on for it to connect again.
