Just Lowered AWD and put on front lip! (Pic)
I just got my car finally lowered. I put in the Eibach springs for the IS250. They fit fine on my IS250 AWD. Its the perfect amount of drop for me. I just threw the 20"s back on to see how it will look this spring/summer/fall. Im gonna put the stocks back on now. Also i put on the GFX lip last nite too. The car had a pretty big transformation in one day. I still need to put on my roof spoiler and rear trunk lip but its too cold and the 3M tape will not adhere correctly. But i just jacked up the heat in the garage so maybe later. Heres a quick pic i snapped with my phone. The car is filthy with salt because we just had a storm. Heres the pic neways.....
It took me about 30mins to install the front lip. I didn't use a jack for the installation although it would have been easier to see if it was up on the ramps. Its easy to do! Good luck.
Ill take off the lip if i have to go out in a blizzard;which i never do. Its 9 bolts and 2 push pins. Simple uninstall. the drops not too low when its on the stock rims there is plenty of ground clearance. I hope this winter mimics the past two, we didn't get much snow at all last year.
No rubbing issues, heat gun trick solved it. Im running 245/35/20 Falken 452's all around. the rears have a slight stretch. I think my front offset is 34, and my rear is 36. Im happy with the combo. the tire fits the fender well perfect to my liking.
