Tech Info Needed...
Old Sep 7, 2007 | 05:01 AM
Cornellian's Avatar
Cornellian
Default Tech Info Needed...
Can any of you guys with access to TIS provide information on Bore & Stroke for the IS350?
-Thanks
Old Sep 7, 2007 | 07:00 AM
Kurtz's Avatar
Kurtz
I don't have access to TIS, but I do have access to google!
Bore and stroke on the IS350 is 3.70x3.27 or 94mm x 83mm if you prefer (compression is 11.8:1 if you're curious)
Old Sep 7, 2007 | 07:35 AM
Cornellian's Avatar
Cornellian
GOOGLE!!
Thanks a lot! I'm busy working on a project and doing a lot of research for other stuff and for some reason google never came to my mind for this issue.
Old Sep 7, 2007 | 07:37 AM
ben_r_'s Avatar
ben_r_
Just FYI you know you can pay 10 bucks to have access to TIS for a day right?
Old Sep 7, 2007 | 07:52 AM
Cornellian's Avatar
Cornellian
Yes, I know. I worked at Toyota. I just needed this info. Usually, I don't need TIS so, I don't bother to pay.
Old Sep 7, 2007 | 10:47 AM
Cornellian's Avatar
Cornellian
Anyone know the rod ratio for the is350 (even better would be ConRod length & Crank radius)? OR. Do you know if TIS will have it (Although, I doubt it)? Maybe it's time to join up.
Old Sep 7, 2007 | 01:52 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Radius is 1/2 stroke. Main journals are 61mm and rod journals are 53mm. TIS does not give a rod length specification, only a twist specification. Typical Toyota is 1.65 rod ratio, but without measuring, that's just a SWAG.
Old Sep 7, 2007 | 02:40 PM
Cornellian's Avatar
Cornellian
Thank you.
I guess 1.65 should be good enough. And it should knock of a few HP from my analysis...
inxexisten
IS F (2008-2014)
16
Oct 29, 2007 07:40 PM
Chaser07
Oct 1, 2007 01:44 AM
myko
Jul 13, 2007 02:54 PM
Patient215
Jul 6, 2006 10:38 PM
shoei
May 26, 2006 10:02 AM
