ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   Car Won't Start (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/297383-car-wont-start.html)
01el Jul 30, 2007 06:32 PM
Car Won't Start
My IS won't start. The key is detected, the radio, A/C works but won't start. The brake pedal is jammed, engine light stays on. I just received the car on Friday (July 30, 2007). Did anyone have this problem? Any solutions?
Belmont Jul 30, 2007 06:34 PM
Ouch! Is the car in park?
(You never know)
lobuxracer Jul 30, 2007 06:36 PM
Does the LED in the start switch turn green when you press the brake with the key in the car?
01el Jul 30, 2007 06:37 PM
(You never know)
Yes its in park, I even put the hand brake on.
01el Jul 30, 2007 06:42 PM
I pressed the brake pedal firmly and it started!
supaIS350 Jul 30, 2007 06:43 PM
(You never know)
I was thinking the same thing.
Or call lexus roadside and tow it to the dealer.
jasonviper Jul 30, 2007 06:55 PM
yeah what probably happened was that you pumped the brake pedal and it becomes stiff so you cant depress it far enough to start,so you have to press extra hard on brake pedal to activate push button
skyraven4 Jul 30, 2007 07:31 PM
happened to me to, ended up just exiting the car, locking, unlocking, going back in and pressing on the brake pedal hard and pushed the ignition...
if you have the brake pedal not pushed hard enough when you hit ignition...seems the brake pedal locks up 1/2 way
