Alignment
Old Jul 25, 2007 | 05:24 PM
THoon's Avatar
THoon
Default Alignment
This is probably a stupid question, but when you get an alignment done do they center your steering wheel? My car goes straight when I take my hands off the wheel but the wheel is pointed at about 1 o'clock 1:30.
I was trying to turn back out of a street that was flooded and I hit the sidewalk really hard with my passenger side front wheel. There's a scuff mark on the rim. I didn't notice the steering wheel until about 15min later.
I called my dealer and they said it's $100, is that too much? I don't really trust walmart or the other small shops around here.
Old Jul 25, 2007 | 05:57 PM
sinister2c's Avatar
sinister2c
umm dude...i think you bent the lower control arms. 1 o'clock seems like some suspension damage to me.
Old Jul 25, 2007 | 06:06 PM
CWS's Avatar
CWS
Lexus of Austin wanted 170 to align mine. Yes, they straighten the steering wheel to match the straight wheels. Take it to Lexus (in case you need special parts.)
Old Jul 25, 2007 | 08:46 PM
THoon's Avatar
THoon
It's more like between 12 and 1 o'clock. Should I tell them I hit a curb or should I just tell them I need an alignment? I feel like if I mention it, they'll rip me off and say everything is damaged and needs to be replaced.
Old Jul 25, 2007 | 09:04 PM
Junghyuk2's Avatar
Junghyuk2
I did mine @ 10k service,
factory warranty covers 1yr/12k for the alignment,
hope there's no major damage...
Old Jul 25, 2007 | 09:10 PM
sinister2c's Avatar
sinister2c
well if they see the curb mark on the wheel and that caster is off on that side...it will be a sure sign you hit something.
the hit probably bent a control arm causing your toe and caster to go off on that side.
Old Jul 26, 2007 | 05:50 AM
bagwell's Avatar
bagwell
just tell them to align it....just becuz you have a scuff on the rim doesn't mean they can't align it.
Old Jul 26, 2007 | 07:15 AM
4TehNguyen's Avatar
4TehNguyen
really need to check if there is suspension damage tho
Old Jul 26, 2007 | 07:58 AM
firdue's Avatar
firdue
i took my car to be aligned at lexus here in houston (the steering wheel was also off-centered between 12-1). they charged 100 and everything seems fine now.
Old Jul 26, 2007 | 11:19 AM
THoon's Avatar
THoon
I went back to the street where this all happend and it looks like I actually an into a huge pothole when I was turining around. The whole street was flooded so I couldn't really see anything but I was pretty sure I was a car length from the curb and I heard a lot clunk. I went to a parking lot to check what happend and I saw the scratches on the rim so I assumed I ran into the curb. I thought I ruined my front bumper. So it looks like the pothole just messed up my alignment, but I'm also hearing a vibration on th highway when I go over 70mph. It's a very faint voom....voom....voom pulsating sound. I don't feel it in my steering wheel.
Old Jul 26, 2007 | 12:50 PM
Gernby's Avatar
Gernby
I wouldn't tell the alignment shop that you hit anything. If there is suspension damage, it will be obvious when they align it. There's no reason to give them an excuse to charge you more. You probably did tweak your front wheel though. If you take it to Discount Tire, they can check to see if it is bent, and can even have it repaired pretty cheap.
Johnhav430
Jan 24, 2019 05:12 AM
WLGS01
Sep 17, 2012 01:03 PM
Och
Apr 2, 2012 02:04 AM
boobstar
May 6, 2007 09:26 PM
STONER
May 19, 2006 04:41 AM
