Old 12-15-14, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Electrical HELP!!! (Windows won't roll up after battery disconnect)
Old 10-04-10, 04:36 PM
  #31
chikoo
chikoo's Avatar
Originally Posted by Kurtz
When you disconnect your battery it loses track of
"where" the window is in its travel.
So you have to calibrate/reset that.
It's not needed on 09+ models as those have flash memory (seriously) in each window controller to remember the position even after loss of power.
meh
My 2003 non lexus car with power windows did not have a problem like that. What gives? Is lexus behind the curve?
Old 10-04-10, 05:24 PM
  #32
Kurtz
Kurtz's Avatar
Originally Posted by chikoo
meh
Other way around- your 2003 non-lexus had more primitive power windows that worked less precisely (and thus didn't know, or care, where the window was in its travel).
Old 10-04-10, 05:42 PM
  #33
chikoo
chikoo's Avatar
and so how does it help? the older technology also worked great...never broke down. Just trying to nail down the exact reason behind this logic.
Old 10-04-10, 06:04 PM
  #34
Kurtz
Kurtz's Avatar
IIRC the window will actually go faster when it has further to go to get to all the way open or closed, versus when it's nearly there.
(I wanna say there's also a safety element of it knowing when it's meeting resistance but has NOT traveled far enough to be closed all the way but I might be imagining that part)
Old 10-04-10, 09:31 PM
  #35
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
Did your old windows have an auto-up function? The need to re-calibrate after disconnecting the battery is fairly common on power windows with an auto-up function; not just Lexus/Toyota/Scion.
Old 06-14-11, 08:59 AM
  #36
brociouz
brociouz's Avatar
Originally Posted by r1lee
Roll each windows down fully and roll them back up. But do not use the automatic down or up. Once you do all 4, they will work.
You actually only need to roll the windows down ever so slightly (not even halfway, 1 cm will do) then roll it back up and hold it for about 1 second until you hear a clicking sound. This can save you a good 10 seconds.
Old 04-26-12, 09:43 PM
  #37
Adon
Adon's Avatar
I have disconnected my battery, and I tried resetting the windows. But the passenger windows would not even move at all, so how do I reset them? The Auto-Roll on the driver window is fine though.
By the way, mine is a right-hand-drive model if it matters.
Old 06-14-12, 07:02 AM
  #38
outlawgs3
outlawgs3's Avatar
Thumbs up Thanks
Hello, I just bought a used 2006 GS 300, had a couple of issues VSC light, windows wouldn't roll up, and I found both answers to my problems here. Thanks guys, this is an awesome forum--proud new/used first time Lexus owner
Old 06-14-12, 08:28 AM
  #39
doom350
doom350's Avatar
I've had this exact problem too!
Old 10-29-12, 10:07 AM
  #40
Denver
Denver's Avatar
glad i read this...... simple procedure
Old 01-25-13, 11:05 AM
  #41
kenberger6
kenberger6's Avatar
Default How can I do the fix if windows don't move
I had the battery changed and my driver window is stuck in the down position. I am trying to do the fix in the other posts by rolling all windows down halfway and then back up (holding for a second). I cannot do this because my window does not move at all.
What am I missing because I am sure it is something simple.
Old 01-25-13, 11:08 AM
  #42
kenberger6
kenberger6's Avatar
This is the same question I have but I did not see a response. Please help because it is going to snow here and my windows are stuck down.
Old 01-25-13, 11:13 AM
  #43
projectdna
projectdna's Avatar
it's in multiple posts in this thread.
https://www.clublexus.com/forums/5269109-post17.html
Originally Posted by Zmiley
When the battery is disconnected, the power windows must be initialized in order to ensure proper operation.
here is what to do in simple terms:
1. open driver side front window halfway
2. close driver side front window and hold switch for 1 second
3. have a look at the other door window switches (they should be flashing)
4. repeat same procedure with other 3 window switches
Easy enough
Old 01-25-13, 11:21 AM
  #44
kenberger6
kenberger6's Avatar
I looked at the threads but my drivers side window does not move and that is step 1. If I cannot do step one then how do I do the other steps?
Old 03-11-13, 12:25 PM
  #45
eburggx470
eburggx470's Avatar
Such a simple fix! Thanks for the help. I have a 2004 GX470 and had disconnected the battery.
Quick Reply: Electrical HELP!!! (Windows won't roll up after battery disconnect)
