Mark Levinson Head unit WORKS, without ML amp
1 Attachment(s)
Oh hell yeah, I have installed the ML nav unit into my cousins car. IT WORKS. THE ML WORKS even without the optical cable leading to the back!
I dont think there is a digital audio cable leading to THe decoder is in the Navi unit. THe cables circled in red is the digital audi cable! BTW, ML unit is no longer for sale! |
DVD player work?
need more details!
Basically you just need to connect the two cable that is circled in Red and the cable that is circled in green
THe Green circled connection is the video feed THe Red cable is for the DTS and DD Decoding. I just installed the unit into my cousins car. Works perfect without an ML amp! However, I did install the ML+NAV as a package. But looking at the NAV+ML unit I installed... vs other peoples non-ML navi... they are the same. |
so did you just do an ML + Nav swap into a non-Nav, non-ML car? im confused?
Originally Posted by IS_250
(Post 2420723)
Yeah, more details please. :eek2: |
So if my IS is an non-Navi unit could I just do the swap? Pls let us know! Thank you,
The DVD player is working fine.
I am pretty sure that all you would need is a ML head unit and the two cables. if you want to watch DVDs I swapped put in an ML DVD+Nav at the same time, so I am not sure if there is something you need to do to turn it on. All US nav systems have the same connectors behind the nav. So it should work. I am mostly surprised that the audio worked without the ML amp, since the digital audio is supposed to be sent to the ML amp. |
Originally Posted by ISbb
(Post 2420784)
PITA. And I have no idea where the GPS antenna goes. |
thank you for answering my question... I would like to know whatif I just wanna to have DVD function. I don't need the Navi system at all... thank you
Wait, you want the DVD Changer in a non nav car? I can tell you for sure it will NOT work.
I put the ML head unit in my cousins car without Nav. the controller would not recognize DVDs or CDs. It would just stay at Aux. |
Good job tqlla3k!
Nice! but do you have better sound quality over the base pioneer set up?
Thanks Technique
STIG, I doubt there is any inprovment in sound, other than the fact that my cousin can now play DTS and Dolby Digital. Most of the processing magic I suspect is in the amplifier, And an upgrade in speakers |
So if my car comes with navi but no ML, all I need to do is buy a ML dvd slot from the dealer and (what wire and how many?) so that I can watch DVD?
