Navigation tint issue
Old Aug 17, 2006 | 11:54 AM
kenjimaru's Avatar
kenjimaru
Default Navigation tint issue
Guys,
About the get my window tinted this weekend, and i just want to make sure that the Navi Antenna locates at the front windshield instead of the back so the metallic tint will not affect the signal.
Thanks for all the input!
Old Aug 17, 2006 | 12:03 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
If you want to make sure it doesn't impact your navigation, don't get metallic tint at all, regardless of antenna location (get ceramic or non-metallic).
Many members who have metallic tint on Lexus on our forum end up stripping it off at a later point once they run into issues with the nav.
Old Aug 17, 2006 | 12:10 PM
ULTiMaX99's Avatar
ULTiMaX99
where are you going to get your tint at?
Old Aug 17, 2006 | 12:29 PM
mwaull's Avatar
mwaull
is solar guard a metallic film?
Old Aug 17, 2006 | 01:35 PM
kenjimaru's Avatar
kenjimaru
thanks for all the response, I am now thinking about getting probably the metallic on the front/rear windows and have the ceramic done at the back probably. I don't know if anyone here had done it in that fashion?
Btw, I had an appointment with Best in Tustin, I've heard lots of great things about them.
Old Aug 17, 2006 | 01:45 PM
socalJD's Avatar
socalJD
They also have 'hybrids' which are partial metal and not fully metallic.
If you don't mind the cost, just do ceramic all around.
If you must do metal, use the hybrid.
I went with a premium dye, it was really inexpensive compared to ceramic & metallic (labor's the same, so only difference is the film) . . .
Old Aug 17, 2006 | 01:57 PM
kenjimaru's Avatar
kenjimaru
How much would the ceramic cost compared to the hybrid ones?
Old Aug 17, 2006 | 02:04 PM
socalJD's Avatar
socalJD
The premium dye is cheapest.
Hyrbid is next, then metallic.
Ceramic is the most expensive.
Actual cost depends upon the tint dealer . . .
Old Aug 17, 2006 | 02:09 PM
kenjimaru's Avatar
kenjimaru
ic, thanks for the help
Old Aug 17, 2006 | 08:34 PM
rys's Avatar
rys
Just so you know, the NAV antenna is on the Windshield next to the rear view mirror.
You shouldn't have any problems with the NAV regardless of what sort of tint you use.
-Brian
Old Aug 18, 2006 | 10:34 AM
socalJD's Avatar
socalJD
I used to think this too, seemed logical enough. Now read Dave's post (#2) - I don't know about you, but I put a lot of stock in the forum admin's opinion, so if he says there ARE problems, I'd err on the side of caution - YMMV . . .
Old Aug 18, 2006 | 02:07 PM
rys's Avatar
rys
Dave drives a GS per his forum name.
The GS NAV antenna is NOT on the windshield. That's why he's seen problems, and probably has heard problems from other GS forum members.
-Brian
Old Aug 18, 2006 | 03:06 PM
onihc's Avatar
onihc
I heart Honda
Check this out. Some people have issues with their nav with no tint at all. https://www.clublexus.com/forums/sho...d.php?t=227612
Old Aug 18, 2006 | 03:08 PM
pocky's Avatar
pocky
mooncake master
I have Madico Onyx, which is metallic tint on all my windows except for the windshield. I have Madico Ceramic on the front windshield. I assure you for the 2IS, there is NO problems with my Navigation system. It works flawlessly. Other cars will be different like per DaveGS4. He owns a 2GS, the Nav antenna could be in a different position. Ours is in the front dash, above the headunit I believe.
Old Aug 18, 2006 | 03:12 PM
rys's Avatar
rys
No the unit above the head unit is the TPMS Tire Pressure Monitoring System ECU. The NAV unit is on the front windshield behind the rear view mirror.
-Brian
