NEED help quick..!!
Old May 5, 2006 | 11:24 PM
sleepy1711's Avatar
sleepy1711
Default NEED help quick..!!
Okay guys I tried doing the dvd hack tonite. Since i didn't have caps I just taped the wires together with electrical tape. After doing all the connecting and stuff. My Nav screen doesn't even turn on. Did anyone have this problem when doing the hack?? and if so, how did you guys correct it. Connection problem maybe. Oh yeah one more thing to add when I was cutting the tape. A lil zap came from the wires.. I'm not sure if that had to do anything with it. I hope not...Thanks guys. OH yeah the stereo and stuff still works.
Old May 6, 2006 | 09:37 PM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
Try doing everything all over again. I realized that it is easy to forget to re-plug some of the wires after you un-plug them to get to the back of the Nav. I almost did it to the cigarette lighter wires, and perhaps you forgot some of the wires for the Nav.
Good luck. Hopefully the "zap" is nothing. Doing the nav hack voids your warranty.
Old May 6, 2006 | 09:40 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
haha...did you check the fuses?
Old May 6, 2006 | 11:32 PM
Payam's Avatar
Payam
Voids the warranty on the car or on the nav?
Old May 7, 2006 | 12:33 AM
AgBlue's Avatar
AgBlue
Ouch.. that sucks... I sure hope the zap didn't short anything. When you say the stereo works.. does that mean the screen turns on and that only the nav portion doesn't work or does that include the screen too?
Also, are you sure you cut the right wires, and on the correct ends? I've done two systems (mine and Philips above) and didn't have any issues as long as I followed the instructions carefully. I'd double check everything. If you need help, PM me.
Old May 7, 2006 | 03:00 AM
t0e's Avatar
t0e
Lightbulb
Did you even unplug the battery when you did this?
It sounds like it still had power running through it. Its not good to cut wires and leave them close to one another, while power is still connected.
Old May 7, 2006 | 07:16 AM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
Just the nav.
No need to unplug the battery. I didn't when I did mine.
However, I had the car off. Did you have the accessory power turned on?
Old May 7, 2006 | 01:42 PM
sleepy1711's Avatar
sleepy1711
Well, when i say the nav doesn't work I mean the climate control doesn't work, audio controls don't work, basically all the stuff connected to the nav doesn't work just the clock, I called a serivice guy from lexus and he said bring it in its covered but I didn't tell him that I messed around with it and the nav he says it cost 6g's! urgh, and i'm not counting labour. If it cost that much i'm debating whether i should fix it. wat do u guys thinks. Thanks for the replies I appreciate your time.
Old May 7, 2006 | 01:45 PM
sleepy1711's Avatar
sleepy1711
oh yeah the wire that seemed to short was the green wire on the same connector as the pink wire. i'm not sure if thats the display wire..
Old May 7, 2006 | 01:48 PM
kensteele's Avatar
kensteele
sleepy, did you check for blown fuse?
Old May 7, 2006 | 02:01 PM
GreyDemon's Avatar
GreyDemon
Registered User
man that sucks....I'm sure you could take it to an electronic guy and they could fix it cheaper....try that.
Old May 7, 2006 | 02:05 PM
sleepy1711's Avatar
sleepy1711
yeah, I tried checking out the fuse. Yeah maybe I could check out the electronic guy. But how would they be able to figure out what went wrong?? BTW the fuse is in the passenger side correct(for the nav).
Old May 7, 2006 | 03:18 PM
sleepy1711's Avatar
sleepy1711
Okay guys good news.. I called my buddy thats a honda tech. He said check every fuse not only the nav fuse but every fuse. And i found the problem. IT was the fuse. heheh. .thanks for all your help now i can rest and sleep well knowing i don't have to shell out six g's for a new one. heheh.. and the dvd works great my gf loves it even though she gave me all that crap about how I don't know how to wire things together..
Old May 7, 2006 | 03:58 PM
AgBlue's Avatar
AgBlue
Wow glad to hear it worked out. That was a close one. Enjoy your new car!
Old May 7, 2006 | 05:10 PM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
I'm glad to hear that everything went well.
Thanks for posting this important thread; it will make people aware of possible problems with the hack.
rgardjr
Jan 26, 2011 11:13 PM
wushuboy
CL of Southern California
Apr 19, 2007 03:32 AM
faymouslex
Mar 21, 2007 12:54 PM
Jace7
Jan 30, 2007 12:57 PM
Lex-Luther
Jul 12, 2006 09:15 PM
