Remote window control
Old Nov 13, 2005 | 10:01 PM
KPierson's Avatar
KPierson
Default Remote window control
Is it possible to remotely lower or raise the windows of the IS250 or IS350?
If you can, how do you do it? Also, can you put them back up remotely?
Thanks for the help,
Kevin
Old Nov 13, 2005 | 10:05 PM
roodiggy's Avatar
roodiggy
push & hold the unlock botton on the key to lower. put key in door & hold in the lock position to raise. moonroof is included.
Kailua250's Avatar
Kailua250
You can lower the windows and open the sunroof remotely but as a safety feature you can't raise or close them remotely. To lower and open them, press and hold the unlock button on the remote. The windows stop lowering when you release the button.
Old Nov 13, 2005 | 10:18 PM
KPierson's Avatar
KPierson
Has anyone tried to modify the windows to raise with the remote?
Is anyone interested in working with me to figure this out?
Does anyone have a wiring diagram for the power window switch module in the drivers door?
Thank you,
Kevin
Old Nov 13, 2005 | 10:28 PM
paeko73's Avatar
paeko73
Thank you,
Kevin
Why would you want to do that (raising the windows remotely)? I can see the reason for lowering them remotely (to let the hot air out to cool the car before driver gets in) but not for raising them remotely. Are you trying to lock your car, walk away, then remotely roll up your windows later?
Old Nov 13, 2005 | 10:37 PM
KPierson's Avatar
KPierson
There are lots of reasons, but mostly to remotly raise the windows if it starts raining. It is nice to be able to raise them when locking the car remotely though. Its pretty convienent. I just downloaded the electrical diagrams from Toyotas technical website. I'll look it over and see how easy integration will be.
Old Nov 13, 2005 | 10:51 PM
KPierson's Avatar
KPierson
OK, here is what I found for wiring inside the door:
Power - blue (pin 10)
Ground - White/Black (Pin 2)
Ignition? - Black (Pin 20) (not very sure about this one, but not really needed)
Door Lock Cylinder - Blue (Pin 4)
Door lock actuator (trigger) - Light Green (runs to the actuator, not to the power window module)
Does anyone want to test this out? It should be pretty easy to implement.
Old Nov 13, 2005 | 11:07 PM
paeko73's Avatar
paeko73
I wouldn't mess with electrical stuff in this vehicle. Watch out before it voids your warranty.
Old Nov 13, 2005 | 11:33 PM
KPierson's Avatar
KPierson
Haha, I guess I have a natural instinct to hack up the wiring in any vehicle I own (but, like I said I don't currently own an IS). If anyone is interested in this project check out: http://www.kptechnologies.com/forums....php?p=495#495 for some more information. This modification has been performed on a wide variety of different vehicles, and in most cases, will keep OEM anti pinch detection enabled while remotely raising the windows.
Old Nov 14, 2005 | 07:49 AM
wolverine's Avatar
wolverine
i called my dealer about turning off my DRLs and i think he said under personal settings the can make the control close the windows....not sure tho
Old Nov 14, 2005 | 08:06 AM
TheRupp's Avatar
TheRupp
That would be cool! My neighbor's E-Class does this by holding the lock button and I think it's a great feature. Too bad his car spends more time in the shop than it does in the garage.
Old Nov 14, 2005 | 03:35 PM
KPierson's Avatar
KPierson
I looked through the owners manual and it wasn't listed under customizable options. It says you can shut off the remote down, but nothing about enabling remote up.
Speed controlled door locks is a programmable feature, that is pretty cool!
Old Nov 14, 2005 | 04:31 PM
mofogasm's Avatar
mofogasm
yea but what kind of weird random number is 13mph
Old Nov 14, 2005 | 04:41 PM
Dr C's Avatar
Dr C
On my AUDI S4, you can remotely close the windows and the sunroof.
Old Nov 17, 2005 | 09:26 PM
KPierson's Avatar
KPierson
Its definately a nice feature to have, it definately should have been included from the factory.
