How to remove the fuel pump relay?
Old Jan 22, 2025 | 06:32 AM
Umar37's Avatar
Umar37
5th Gear
Default How to remove the fuel pump relay?
Ive checked the manual and it says the fuel pump relay is the big green one and the grey 25 amp fuse. I can remove the 25 amp fuse just fine but the green one just doesnt come out, i would try harder but i dont want to break it, is there like a latch? The grey thing on the side doesnt seem to be one so im at a loss
Old Jan 22, 2025 | 12:52 PM
2013FSport's Avatar
2013FSport
Yoda gods didn't mess around with the contacts and they are a bugger to get out. There is no latch. If you do pry it, use plastic tools as some things are powered.
Why do you want it out?
Old Jan 22, 2025 | 01:05 PM
Umar37's Avatar
Umar37
5th Gear
Hmm, alright I'll try harter then. I want it out so i can clear the fuel lines of all gas and blow it out.
Old Jan 22, 2025 | 01:22 PM
Umar37's Avatar
Umar37
5th Gear
Nah man, i used my big pliers on that thing, it will not come out, is it possible to just remove the 25 amp fuse? Cuz they both say theyre for the F/PMP
Old Jan 22, 2025 | 01:36 PM
MikeFig82's Avatar
MikeFig82
Are you just trying to discharge the fuel system? If so the instructions are below. There will still be some pressure in the lines.
Old Jan 22, 2025 | 01:50 PM
Umar37's Avatar
Umar37
5th Gear
my car was flooded so i wanted to blow out any gas left over so it can start fresh, at least thats my thinking
Old Jan 23, 2025 | 08:49 AM
2013FSport's Avatar
2013FSport
Pulling the fuse is all you need to do then... I pulled the relays out of the coolant system heater (GLW RLY1, GLW RLY2), I had to be pretty aggressive / persuasive / maybe even mean, but they came out so I could test the heater elements.
Good luck, also hold the gas pedal down while cranking and keep that battery charged.
Old Jan 23, 2025 | 09:45 AM
MikeFig82's Avatar
MikeFig82
Another thread explaining of the fuel pump relay removal.
https://www.clublexus.com/forums/is-...ump-relay.html
Old Jan 24, 2025 | 09:27 AM
2013FSport's Avatar
2013FSport
lol....
"There is no easy way. Brutality is the only solution here!"
Old Jan 25, 2025 | 07:43 AM
James654's Avatar
James654
Welp i gave up, and the car works fine now so im good
nishibear
IS F (2008-2014)
Nov 27, 2024 04:58 PM
vadimgal
Aug 26, 2021 07:21 AM
mkivmattho
Apr 7, 2020 01:02 PM
Cjet
Jul 10, 2018 04:43 PM
