2011 headlight hyper flashing blinkers issue
Old Jan 18, 2024 | 08:46 PM
xkenny74's Avatar
xkenny74
10th Gear
Default 2011 headlight hyper flashing blinkers issue
I have a 07 IS350, recently I upgraded my headlights to the updated OEM versions, and I have been getting the hyper blinker issue inside (green arrows) and outside from the headlights and the tails. I already swapped my low beams/signal bulbs out, but it's still doing the same thing and I'm unsure what the cause is. Does the change require a resistor or a fuse swap?
Thanks for all the replies and helping me out.
*PROBLEM SOLVED, RELAY FIXED THE HYPER FLASHING*
Old Jan 19, 2024 | 07:36 AM
Alternet's Avatar
Alternet
usually when this happens it means the flasher relay is bad... but it only starting after the headlights were swapped is a little suspicious. Did you put any led replacement bulbs in? or standard incandescent?
Old Jan 19, 2024 | 08:30 AM
MikeFig82's Avatar
MikeFig82
This thread is dedicated to the 2011+ headlights it has 45 pages of comments.
I'm sure you can find your answer there, or post a new comment there if not.
https://www.clublexus.com/forums/is-...ispreloading=1
Old Jan 19, 2024 | 08:35 AM
ohiois350's Avatar
ohiois350
do you upgrade the +11" signal relay fuse block too? I did the MY12 headlights upgrade on my 07" IS350 and I did swap out the turn signal relay block under the steering wheel, that must to take care the hyper flash
Old Jan 19, 2024 | 12:50 PM
xkenny74's Avatar
xkenny74
10th Gear
I swapped the low beams/blinker bulbs from my old headlight to the new one only.
Old Jan 19, 2024 | 12:54 PM
xkenny74's Avatar
xkenny74
10th Gear
Didn't try upgrading my fuse relay block. Do you think I would need to replace the entire block itself or just a single fuse replacement for the headlights?
Old Jan 19, 2024 | 07:36 PM
ohiois350's Avatar
ohiois350
just a signal relay block under the steering wheel shaft, that what I did when I upgrade MY12 headlights on my 07 IS
Old Jan 19, 2024 | 11:12 PM
xkenny74's Avatar
xkenny74
10th Gear
I'll try it out thanks, if it doesn't work I'm probably going to see if I can rewire my headlights with the thread above that was linked to me. Thanks!
Old Jan 20, 2024 | 03:24 PM
Zmon's Avatar
Zmon
To provide some additional info..... I did a swap with the 13 headlights on my 08. You only need to replace the flasher relay under the driver side dash, nothing more. Here's a post on part numbers and its actual location: https://www.clublexus.com/forums/is-...ml#post7184143
Old Jan 20, 2024 | 11:46 PM
xkenny74's Avatar
xkenny74
10th Gear
Thanks! I'll buy this one instead of the one I was looking at lol.
Stonehengeheel
Jan 3, 2024 04:48 PM
barnyarnavitch
IS F (2008-2014)
Jun 1, 2023 11:04 PM
Lexusloud
Jun 11, 2018 07:49 AM
khoab88
Apr 19, 2013 08:33 PM
