I have a 2007 is350 with more then it’s fare share of electrical problems one of which is that it’s navigation screen/ system has never worked while i’ve owned the car. I know it worked a few months before but not sure what happened. I’m coming up in a year of owning the car i’m November and the screen or lights on the system has never worked
tonight while leaving work my car didn’t start and i needed a jump, after jumping the car the screen turned on and said “ check the system” i was able to see my climate controls and it looked fine
during my drive home the screen seemed to reset and went black but not off and was unresponsive
i got home turned the car off then on again and it was like nothing happened
i only have this one picture because it all happened so fast if anyone has any ideas or help
it would be greatly appreciated
These have a mechanical hard drive in them, I'm not saying your failed as you need to run a diagnosis.
There is a combo of ignition on, info button, and some other switch. I've posted it before. Do a search using my name and electronic diagnostic. It will give you much more information and direction towards which sub-system is at fault.
[QUOTE=2013FSport;11595583]These have a mechanical hard drive in them, I'm not saying your failed as you need to run a diagnosis.
There is a combo of ignition on, info button, and some other switch. I've posted it before. Do a search using my name and electronic diagnostic. It will give you much more information and direction towards which sub-system is at fault.[/QUOTE
thanks i’ll take a look at this and try it out thanks for the insight
i’ve been looking for the list for awhile now and can’t seem to find it. any way you can share
a link
