Replace rear ABS speed sensor
Old Mar 2, 2023 | 04:14 PM
markdav801's Avatar
markdav801
Default Replace rear ABS speed sensor
All,
Anyone have any references or input on replacing rear ABS speed sensors?
08 is250 RWD
Old Mar 3, 2023 | 10:01 AM
MikeFig82's Avatar
MikeFig82
This is for the 2014 model. It should be close to what you're looking for. Though you're only going to remove the ABS sensor from the connector clip on the body. So you won't have to remove the internal trunk liner. As the sensor should be split in two wiring parts. I could be wrong I haven't checked mine. See PDF instructions in this thread.
https://www.clublexus.com/forums/sus...l#post11146705
Old Mar 3, 2023 | 10:10 AM
markdav801's Avatar
markdav801
From the looks of it, the sensor has the clip on it. I'm hoping that the sensor\clip is all that is needed to be removed and is plug in play at the sensor...
https://imgur.com/a/s0I4ZYv
Old Mar 3, 2023 | 10:40 AM
MikeFig82's Avatar
MikeFig82
Yes that's what im seeing on RockAuto as well.
Old Mar 3, 2023 | 10:57 AM
2013FSport's Avatar
2013FSport
Has some other work been done to it? These sensors really don't fail that often. Axle and bearing work is known to take a toll if done incorrectly and after that it's wire damage.
Are any of these a factor in your case?
Old Mar 3, 2023 | 11:41 AM
markdav801's Avatar
markdav801
I noticed it flickering on and off over the past few months. Maybe it was flickering due it needing rear wheel bearings which I recently replaced and hoped that the light would resolve itself.
It didn’t. My mechanic stated the right rear needed to be replaced based in the error code.
Old Mar 4, 2023 | 08:36 AM
2013FSport's Avatar
2013FSport
Try removing it and blowing compressed air into the hole while spinning that axle.
Again, they seldom actually fail.
If the WB was replaced, they likely took a short cut that lead to this condition.
Yoder513
Sep 28, 2022 06:34 AM
Kjoy28
Suspension and Brakes
Oct 17, 2021 11:40 AM
DixieLex
Jul 18, 2017 08:23 AM
BlackRX300
RX - 1st Gen (1999-2003)
31
Jun 12, 2016 10:53 AM
lexsc3
Aug 24, 2010 10:44 PM
