is300 not running right
so i bought my 03 is300 2jz a few weeks back from a buddy, he had cracked the radiator, and when i bought it, i replaces the radiator and coil packs. along with the spark plugs hoping that would help, well it starts and drives but doesn’t drive far. it seems as if there’s not much power, and doesn’t sound as if it’s shifting right. i went ahead and bought a new mass air flow sensor hoping that would be it, it wasn’t, it kinda helped. the car when it stops it’ll start to shake. i don’t know what to do. can anyone plz help
Is there an engine light on? Have you pulled codes?
Shaking
I'd replace the spark plug wires as well. Mine were cracking bad at around 100k.
Will cause misfire,
If you see the traction light going on and off it's probably that
Will cause misfire,
Jakez
IS - 1st Gen (2001-2005)
18
10-20-11 04:37 PM
LEXISM
10-06-11 07:06 AM
