ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 1st Gen (2001-2005) (https://www.clublexus.com/forums/is-1st-gen-2001-2005-166/)
-   -   rusty turbo exhaust housing (https://www.clublexus.com/forums/is-1st-gen-2001-2005/918695-rusty-turbo-exhaust-housing.html)
brett14 05-15-19 08:11 PM
is there anyway to clean the rust and protect it from the future rust
or throw a turbo blanket on it and cover it
Pittsy 05-16-19 11:39 AM
Get it ceramic powder coated.
daddystop 05-17-19 10:41 AM
Yeah, you'd have to bead blast the rust and then coat it with paint or powder coat. Ceramic coating (done properly) is quite expensive.
I would advise against just covering it w/ a turbo blanket but I've also seen plenty of rusty manifolds that were operating just fine. I'd coat it if it were me.
Pittsy 05-17-19 01:04 PM
Yes, I forgot to mention, It's quite costly, but it will also help with heat. If you did get it coated and also put a blanket over it would yield you the best results. If you did nothing and just left the rusty manifold, youd probably be fine as well. I would coat and cover.
