IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
compression
Old May 19, 2003 | 04:16 PM
1PhatLexus's Avatar
1PhatLexus
Registered User
Question compression
hey, can anyone tell me what the compression is on the IS3 Auto? My friend keeps telling me that if I put a turbo kit on my car, I won't be able to run more than 5PSI of boost. If I do, I will blow the engine!! Is that true?
And also, all you folks who did put turbos on your IS3, what else is REQUIRED so I don't ruin my engine if I put a turbo kit in? ex: camshafts, apexi controller, camgears, pulleys, pump, pistons, valve springs.
thanks
Old May 23, 2003 | 05:24 PM
EmoDragRacer's Avatar
EmoDragRacer
Default Re: compression
thanks
compression is about 10:5:1 you can run about 7-8 psi safely on stock compression on pump gas...
Black1129
Sep 21, 2015 09:42 PM
AlwaysDTF
Performance
54
May 15, 2011 02:25 AM
B-DUB
Performance
31
Feb 8, 2007 08:54 PM
SC394
Jun 5, 2004 05:39 PM
GlobeCLK
Performance
16
Apr 10, 2002 10:33 AM
