Need help 01 is300
Need help 01 is300
Hey all i'm new to these forums and need some help i own a 01 and the other night everything was working fine. My radio witch is a after market Jvc currently stopped working the next day i checked all the fuses none were blown. i checked the wiring behind the radio and redid them all an checked the fuse an everything is fine. I don't know what to do at the point. Currently my Dash where the ac button an everything is the nights aint working but they do work when i click on them just not the lighting. Any suggestion what i can do cause i really don't want to take it to car toys an spend $300-500 for a fix that i can do myself.
Thank you
Thank you
live.love.laugh.lexus
First off, welcome to clublexus. You may have already checked, but have you checked the kick panel fuses? And if so, have you verified continuity with a DMM (to make confirm that they are not blown)? The AC button may be a mechanical switch (normally open or closed) so I could see that working ok without the button lighting. Also, try disconnecting your radio to see if everything works without it. Good luck!
Nattooshie
04-21-04 07:19 PM
