ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 1st Gen (2001-2005) (https://www.clublexus.com/forums/is-1st-gen-2001-2005-166/)
-   -   Engine won't start! Help (https://www.clublexus.com/forums/is-1st-gen-2001-2005/735086-engine-wont-start-help.html)
Is300azn Mar 23, 2014 03:00 PM
Me and my dad have changed the water pump seals, head gasket seals, valve cover seals, basically most of the engine that needs seals. We reassembled the whole engine inspected it bottom to top, put the key in the ignition and just makes the sound when you first turn on your engine but won't turn your engine on. Someone that could help us, we would appreciate it.
Is300azn Mar 23, 2014 05:17 PM
Quick update. So we bought starter fluid sprayed it in the air intake. Took about 7 times till we heard it turn on, but didn't really sound like it was, it sounded like it was hesitating, so we tried it again for about 5 times and now it makes a sound close to the trottle body each time we turn the key to ignition it doesn't crank no more. Is this the end for my 2jz ge engine?
PIONEER Mar 27, 2014 10:51 PM
pull codes. see what its complaining about.
need the following to run.
fuel
spark
oxygen
see whats missing.
Black1129 Mar 28, 2014 08:44 AM
Check your timing belt it's possible that it's not timed right. Check you compression check your fuel check your spark.. It's something you guys replaced so check your work throughly.
Is300azn May 22, 2014 08:21 AM
Thank you all. Got her running again.
