IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Gte block
Old Jan 31, 2013 | 09:18 PM
Is300chief's Avatar
Is300chief
Default Gte block
Can you put the gte block on the is300? Just the block and not change the head. I wanna rebuild my block but found a brand new gte block for cheap
Old Feb 1, 2013 | 06:38 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
they are the same / similar... you will have to examine the oil pump closely as there are differences between them due to having different crank sensors...
Old Feb 1, 2013 | 11:37 AM
madchyers's Avatar
madchyers
GTE blocks will work, but certain years have different motor mounting spots. I forget what the compatible years are, how much is the block? Cause you can just buy some GTE internals and replace the GE internals with them.
Old Feb 1, 2013 | 11:46 AM
mitsuguy's Avatar
mitsuguy
Good point and Id have to double check to be sure, but all newer blocks have both mounting locations...
I agree also it'd have to be pretty cheap to not just swap to GTE internals...
Old Feb 2, 2013 | 10:29 AM
Is300chief's Avatar
Is300chief
The block is 1200 brand new
Old Feb 2, 2013 | 01:41 PM
madchyers's Avatar
madchyers
GTE internals - $300-$400
Old Feb 2, 2013 | 03:48 PM
mitsuguy's Avatar
mitsuguy
or less! I paid $100 for mine, shipped...
for $1200, you could buy forged pistons with rings and rods... couple hundred for machine work, done... so, spend a few hundred extra and get a bottom end that'll handle 1000 all day long reliably...
Old Feb 2, 2013 | 04:22 PM
tjmhillz's Avatar
tjmhillz
It all depends on if he is doing the work or not. If he isnt doing the work himself. I would say go with the gte block. Just thinking if he gets the gte rods and pistons. Then he has to take it to somebody to install and if his stock block is out of specs then he has to pay for machine work which could add up. I would just go with the gte block slap the ge head on and call it a day. Also are you planning on going boost? Either way you cant go wrong. just depends on your goals and wallet haha.
Old Feb 2, 2013 | 09:11 PM
mitsuguy's Avatar
mitsuguy
I can get a block hot tanked, milled and honed for $200... in spec or not...
anyone capable of reading instructions can put it all back together...
Old Feb 3, 2013 | 08:22 AM
tjmhillz's Avatar
tjmhillz
^^Agreed. OP what are your goals for the new block or if you rebuilt your block? Do you plan on going boost or just freshening up the motor because of mileage?
Old Feb 3, 2013 | 06:56 PM
Is300chief's Avatar
Is300chief
Right now it's just for mileage but I'm getting a raise soon so I might boost it lol
But will see what happens I'm just trying to have a reliable car right now
newdude1
Dec 23, 2014 12:13 AM
soarer13oy
Performance
Dec 2, 2014 02:15 AM
evileagle
Sep 5, 2007 05:01 PM
silent1pro
Dec 14, 2006 08:23 PM
