need help on wheels fitment
2 Attachment(s)
hi guys i need some help on wheels fitment i dont have too many $$ to spent so i was looking on those wheels:
xxr 521 18x 8.5 +25mm 18x 10 +25mm xxr 526 18x 9 +25mm 18x 10.5 +20mm i'm looking for a little bit aggressive thanks |
I have the 521's, theyll fit nice. But they're actually
18x8 +30 18x10 +25 You'll have to do a fender roll so they wont rub. Im running em on 215/40 & 225/40 |
thanks bro.... how negative camber did you go on the back? also and lower 2' all around on springs that would be good enough?
I have about a 2° camber. 2 inch drop should be good, i would go with coilovers though so you can play with your set up & get it perfect to your taste.
1 Attachment(s)
ok... i will thats going to be my next plan......
soooo what about the 526's those would be to aggressive? |
1 Attachment(s)
or just wait for the news 511's
18x 7.5 +42mm 18x 9.5 +35mm |
I think for the offset on the 526's you will need a fender roll + minor fender pull.
Those 511look pretty nice, & with those offsets you won't need and fender roll or anything, but you might end up needing some wheel spacers if you want an aggressive look. To me, +30-35 offset all around is perfect, but it all depends on your taste & what look you're trying to achieve. |
thanks altezza i think my best choice are the 521's i like the way your is look:thumbup:
i like a little bit aggressive |
No problem, so you found my car huh? Yeah, the 521's look nice. I always get compliments on the wheels, just remember that you're gonna need a feeder roll if you don't want to rub.
Post up some before & after pics of your ride once you get em. |
i wll thanks a lot bro
one more question bro if look in here for the 521's wheels
http://www.nlmotoring.com i'm looking the gloss black since my is is solar yellow for the front there are two different offset they have 18x 8.5 +35mm 18x 8.5 +25mm which offset is best for the fronts? |
Go with the +35, cuz if you go with the +25 you will need a fender roll and fender pull or negative camber or you will rub a lot.
thanks bro for all ur help :thumbup:
:No problem...
By the way, you sold me on those 526's! So i just ordered some today, i ordered the 18x9 +35 all around chromium color. Cant wait to get em & change the look on my ride a little. Plus i had already bought new tires about a month ago so they're ready to be mounted & slapped on!! Tires are the:wo ontinental Extreme Contact DW. I LOVE INCOME TAX TIME!!:woohoo: |
hahahaha you change my mind now i dont know which one buy
