Camber kit God Speed upper control arms vs. SPC ball joints?!
I recently picked up a 2001 IS300 the person before me did not know what they had, obviously explaining two to three wheel studs snapped off on each rim, a lowering kit with the camber so out of whack that all 4 tires are showing wires. So here is my question, to you... Should I go with the godspeed upper control arms? Are they safe? or the SPC ball joint camber kit? Any help would be great thanks you?
I have the same question.. Not sure if it's "reasonable" to assume the SPC's (for $400) would be any more durable or better than Godspeed's or even Manzo's... PLEASE HELP! Has anybody installed either of these... or even Megan's? I need to know which ones I should buy. Just want the front camber to match the back, since I've installed SAGE rear RCA's (30mm drop)
Also- I noticed SPC says their adjustable front UCA's are adjustable up to ±1° Caster and ±2° Camber change. *Manzo's, Megan's, and Godspeed's all say
Specialty Products ...$350-$400! (which is almost the cost of the other (cheaper) brands...for BOTH adjustable FRONT and REAR UCA's!) I'm just wondering how the ball-joints are in ones like these:
https://www.ebay.com/itm/Rear-Upper-Pillowball-Camber-Kit-Silver-For-98-05-Gs300-Gs400-Gs430-01-05-Is300/272885330866?fits=Model%3AGS430&hash=item3f893bb3b2:g:KHYAAOSwbe5ae6ba&vxp=mtr
Manufacturer Part Number: 72270
https://www.ebay.com/itm/SPC-Adjustable-front-upper-control-camber-arms-caster-GS300-GS400-ball-joint/323189081554?fits=Model%3AGS430&epid=22017017632&hash=item4b3f9205d2:g:kcQAAOSwrRlZpj9s&vxp=mtr
This pair of Lexus GS adjustable front upper control arms will give you ±1° Caster and ±2° camber change. Simply replace the OE front upper control arms and dial in your suspension angles with our patented sliding ball joint and caster plate. Whether you want to tune your suspension for the ultimate in handling performance, minimize tire wear or easily move back and forth between the two settings, these are the arms to get the job done.
Front Adjustment range:
Camber: ±2.0°
Caster: ±1.0°
Installation time: .6 hr/side
Required: 1 kit per axle
Godspeed ....$195!
Manufacturer Part Number: AK-091-B
https://www.ebay.com/itm/FOR-LEXUS-98-05-GS300-GS400-GS430-GODSPEED-ADJUSTABLE-FRONT-UPPER-CAMBER-ARMS/192314273810?fits=Model%3AGS430&epid=2262080266&hash=item2cc6d2f012:g:-sAAAOSwz7NacRf6&vxp=mtr
Fits 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 Lexus GS300/GS430
Heat Treated Harden Steel Alloy Construction; Heavy Duty Ball Joints
Allows Camber Correction Adjustment; +/- 3 Degrees
Engineered To Direct Replacement OE Arms For Easy Installation
No Install Instructions, Experienced Professional Install Is Recommended.
Adjustable Front Upper Camber Arm
.... not sure which ones? Anybody have OPINIONS on the different brands?
Thanks so much for your help, guys...
Mike
MrHarris
06-27-15 04:36 PM
